Old 11-07-2003, 10:10 PM   #1
dug074
'99 leaking coolant
I have a '99 ls, with a 3100, ruffly 60k miles.
She's loos'n coolant out the Intake mani-gasket, drivers side. I thought I had remembered hear'n somthing about a manifold problem with these motors... any help? Warp? Crack? WTF? and when did intake manifolds start carrying coolant!?
Any help greatly appreciated.
dug074 is offline   Reply With Quote
Old 12-13-2003, 09:33 PM   #2
hoosier1
Re: '99 leaking coolant
The intake gasket is leaking. You need to get this fixed soon coolant may get into engine oil. It may be warped- take it to a shop and get it checked for warpage- big bucks if it is warped. Can`t be straightened properly.
The intake manifold has coolant passages on V-Type engines- should have on some in-line engines.
The replacement gaskets from Car Quest or any other supplier are much improved over the original gaskets. The are made of silicon rubber.
Tighten the vertical bolts before the diagonal bolts- very important step.
You should use the new style bolts- they have loctite already applied and should not loosen over time. Be sure to clean out bolt holes.
Its a simple job if you pay attention to disassembly.
hoosier1 is offline   Reply With Quote
1994 Olds Achieva, 3.1 S Leaking coolant rastaron Achieva 1 09-23-2010 12:13 PM
3100 v6 leaking coolant from timing chain gasket? jamc204 Grand Prix 4 06-22-2010 11:18 AM
2002 SE leaking coolant jamc204 Grand Prix 2 06-17-2010 09:56 AM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
91 caprice leaking coolant leaking coolant Maticlee Caprice 12 08-20-2008 09:31 AM
