Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-16-2001, 12:47 PM
82civicwagon's Avatar
82civicwagon 82civicwagon is offline
Question what size turbo?
i'm looking to turbo my wagon, it has a 1.5L em1 motor(2nd gen).what size,and manufactuer would you reccomend? the motor will be fresh when i proceed with the install, cuz i plan on doing its first rebuild here anytime soon.
82 civic wagon
amsoil high flow air filter
apex'i muffler
future motor swap ride
[email protected]
Member of TeaM NiGLeT iNC.
MeMBeR NiGLeT eLiTe GuaRD
more bodyroll than a 500 Lb G.A.W.A.
?WHAT YOU LIKE TO DO WITH PUNANNI?
POONSAI!
Old 12-16-2001, 02:22 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
maybe a T25 Garrett would be your best bet... it's small, but it'll be easy enough for your motor to spin freely and still produce enough boost to make it worthwhile.
but you'll need to fabricate an intake system to attach and seal to your carburetor.
Old 12-16-2001, 11:17 PM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
wow i was gonna say garrett t25 too... anyway dont go too big, hondas dont have a lot of exhaust pressure itll take too long to spool if u go too big, of course if this is going to be a race-only vehicle lag wont be much of a question cuz u can rev the engine up ahead of time, but for a street car i wouldnt get bigger than a 25 or 30 mm. garret, ihi, turbonetics all make good turbos, also the smaller hks ball bearing turbos would bo good for u.
Old 12-18-2001, 04:11 PM
right on i'll have to check those out!
i've also thought of using a smaller turbo to help spool up a larger one, how well that works i dont know but i've heard that it does.
82 civic wagon
apex'i muffler
[email protected]
POONSAI!
Old 12-18-2001, 05:43 PM
drift's Avatar
it's called sequential turbo... it still requires more exhaust pulsing than your motor can generate.
Old 12-19-2001, 03:05 AM
LjasonL's Avatar
Some Guy
if u wanted to go really crazy u could do what is called a divorced turbo, where u have a second, smaller engine mounted elsewhere (likely the hatch) and its exhaust is run to the turbo to spool it, then the turbo is piped into the engine that is driving your wheels. since none of the 2nd engines exhaust is going out of the vehicle through the exhaust system, its all being run to the turbo and then the smaller motor can produce enough pressure to keep the turbo constantly spooled and at full boost all the time. of course as u can prob tell this is not something u just go out and do but requires very extensive and pricey custom mods. also i seriously doubt its legality, and i dont think ive ever even heard of this being done on anything but balls out open class pikes peak cars. but like i said, IF u wanted to go REALLY crazy...
what size turbo to use? Civic_D16Y5 Let's get Technical! 19 02-23-2005 07:44 PM
what SIZE turbo should i get? 91CRXHF '88 - '91 Civic | CRX | Wagon | Shuttlee 7 10-24-2003 10:33 AM
what size turbo will I need? djK1 Forced Induction 10 08-20-2003 10:52 AM
What size of turbo should I choose? (for p10) radicalG20 Engine 49 02-05-2002 09:25 AM
what size are non-turbo FC3S stock injectors rb-26DETT-Z RX-7 4 12-12-2001 10:05 AM
