Go Back   Automotive Forums .com Car Chat > MG > MGB
Old 08-13-2003, 10:51 PM   #1
frogman
Fiberglass leaf springs (Or something better)
New member here and thanks in advance!
I’ve got a 1965 MBG roadster and I’m thinking of updating the suspension (I’m thinking safety first.) but I’m really not sure if it’s worth the time, money, trouble, and punching holes in my vintage ride. Car rides okay on smooth surface but front-end rattles when you hit the unavoidable rut in the road, especially on the corners. I’ve inspected steering and suspension and all seems to be tight. Car is 90% restored by previous owner and has been modified (Weber down draft, Headers, exhaust, and slotted front disc brakes). The rest of the car is original. I’m also experiencing overheating sitting in traffic but I’ll save that for another time.
Again Thanks
Cesar
frogman is offline   Reply With Quote
Old 08-18-2003, 02:11 PM   #2
frogman
Thumbs down Were's the help!
I've had my questioned posted here for a few weeks with no response. Since then I have found my answers else were. I'm sticking to what I got because I don't feel right about punching holes in my car. I've also decided in restoring my MG back, or as close to it's original state.
California pothole patrol were are you!
Cesar
Old 08-19-2003, 09:47 PM   #3
Moppie
Master Connector
Moppie's Avatar
Sorry we couldnt be of any help, AF is big, but its still growing in many areas.
Could you post a link to where you found the information in the end?
That way we might be able to help the next person who comes along.
Moppie is offline   Reply With Quote
Old 09-16-2003, 10:51 AM   #4
V8Conversion
Suspension
I'm sure your fronk end just needs to be rebuilt. The king pins get sloppy and need new bushings etc... Fitting V8 bushings will help firm everything and last a lot longer then the original 2 piece rubber ones.
Check wheel bearing/hubs/tie rod ends/sway bar bushings and steering shart u-joint.
As for fiberglass leaf springs.. I have them on my 1980 V8 Conversion. It greatly improves the ride... I use tube shocks vs. the OE ones. I also have traction bars fitted to control spring wind up.
After fitting the stiffer ft shock valves, it's really a great riding car. Very smooth and comfortable.
V8Conversion is offline   Reply With Quote
XJ Rear Leaf Spring Swap Problems Jim Aldrich Cherokee 1 04-04-2010 09:25 PM
Source for leaf springs, shackles or bushings? Darel51 Villager 0 11-04-2007 04:15 PM
leaf spring or rearend clunk (rattle) hwywolf Sierra 0 08-26-2005 12:28 PM
Leaf springs or Torsion bar? geneM62 C/K 0 09-29-2003 08:07 AM
leafs for leaf springs chascart Ram Pickup | Ram SRT10 1 01-01-2003 06:48 PM
