Go Back   Automotive Forums .com Car Chat > Pontiac > Bonneville
Old 07-20-2003, 01:25 PM   #1
L1_Guerito
Angry Emissions Failed NOX
Does anyone know a cheat to Pass NOX emissions testing, Failed with 3.05 max allowed is 2.5, When I got into to car to move after testing it was running hot. Any advice. Also AC compressor went out, uggggggh just my luck. Is it possible to replace compressor without having to take it to a shop and getting raped!!!!! Please help. My vehicle is 1993 Bonneville SSE has 156K miles on it, where is the EGR Valve anyways? Please help!!!!!! UGGGGGGGHHHHH
L1_Guerito is offline   Reply With Quote
Old 08-06-2003, 04:42 AM   #2
Blue02R6
Re: Emissions Failed NOX
Well check with your DMV where I live if you fail, spend $200+ to get it to pass and it still fails they ignore it.
Yes, and no. Yes, you can replace the compressor yourself. No you can't do it with out the shop. They have to at least recharge the system to make it work. You should also have them recover the refrigerant before you work on it.
My Stable:
2002 Yamaha YZF-R6
1988 Pontiac Fiero
1969 Pontiac Firebird
I might get my '02 SS back....
Blue02R6 is offline   Reply With Quote
Old 09-10-2003, 02:07 AM   #3
89 iroc-z
there is no egr on the 3.8 from 92 on up. but what you have is bad cat. the cat on that car is a 3 way cat and the nox part is bad.
89 iroc-z is offline   Reply With Quote
86 camry emissions fail due to high NOx gujuchokra Camry/Camry Hybrid/Vista 4 04-15-2009 04:01 PM
Emissions fail, NOx - 1226 rajeevesaini Bonneville 4 04-29-2006 10:43 AM
Failing NOX on emission test gmtechnician Deville 6 03-01-2006 09:05 AM
