Old 08-12-2003, 02:23 AM
Heist Heist is offline
Help!!! My car doesnt start coz theres no spark!!
My Car doesnt start!! there is no spark! the starter motor kicks over but there is no spark! help me!!i know its not my immobiliser so help me plaese!!! thanks
Old 08-12-2003, 06:35 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
it could be ur ignitor or ciol, this happened to me, my car stall at a red light and wouldnt start agaion till i replaced my ignitor.
Old 08-12-2003, 07:19 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Could be several things... I have no idea what an immobilizer is...
Anyways, check to make sure that your rotor hasn't fallen off inside the distributor cap.
It could also be the ignition coil... Pull it out and test the resistance of the primary and secondary windings.
Could be your ignitor unit in the dizzy.
Similar thing happened to me a while back, and it turned out to be my alarm system. It completely fried my ignition switch, and even after I replaced the ignition switch, the car wouldn't start. Turned out that the alarm brain was all tweaked out and wouldn't let the car start... Took me 3 months to figure that out.
Hope that helps somehow.
Old 08-12-2003, 08:40 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
The same thing happened to me. I checked all the basics first and it turned out to be the igniter.
Old 08-12-2003, 02:37 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Yup. Igniter and coil are the most likely culprits. You can usually tell when the screw comes out of the rotor, because your car goes Blut! and then you're on the roadside.
When I had these troubles, I replaced the igniter and the coil...and then had to replace the entire distributor.
Flunky
Old 08-12-2003, 06:51 PM
hey ci5ic, an immobilizer is part of my alarm, it cuts power to the starter motor when the alarm is on... so you guys reckon the coil or ignitor? coz i have just done a auto to manual transmission swap would that be anything to do with it? thanks
Old 08-12-2003, 07:14 PM
ci5ic's Avatar
Do you have the clutch pushed in all the way when you try to start it? (car won't start if it's not)
Either that or, maybe switching from Auto to manual you didn't wire up the sensor that senses that the clutch isn't pushed in? I dunno... just a thought.
Old 08-12-2003, 08:46 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
coil or ignitior...both are quite common in 4th gens to go bad....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
my car will run for a few days then the HOT light comes on and the car doesnt start HEET Ninety Eight 0 08-30-2010 11:50 AM
Car Wont Start Vats Wire Spark Help!!!! igot95 Caprice 6 09-23-2008 11:54 PM
Help car won't start - no spark Alexxn 00 Si '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 07-21-2006 11:47 AM
93 Taurus-Replaced Water Pump-Car doesnt start MrTaurus Taurus | Taurus Wagon 3 02-16-2005 06:26 PM
