Go Back   Automotive Forums Car Chat > Toyota > Supra > General
General Discuss anything having to do with Toyota Supra here.
Old 08-15-2003, 01:28 PM
ajrock2000 ajrock2000 is offline
what causes my supra to shake a little at about 80mph and above?
right when i hit around 85+ it starts to shake a little, could it be my tires(i deff need new ones). what usually causes this to happen?
Old 08-15-2003, 02:07 PM
11 sec. mr2's Avatar
11 sec. mr2 11 sec. mr2 is offline
Send a message via AIM to 11 sec. mr2
well this can be a few things. one is it could be very bad unbalanced tires. and if you feel it more in the steering wheel then the body this is prolly it.
two it could be your carrier bearing on your driveshaft has worn out. if you put your hand on the center hump by the back half of the consel and you feel a very strong thump from there this is prolly the problem.
three your shocks could be bad. this is very unlikley but is a possibility. when you travel at higher speeds small bumps in the road can cause your tire to bounce up and down constantly. making a much differant vibration but a vibration none the less. i doubt this is the problem. im sure its mostly your carrier bearing on your driveshaft. or an unbalanced driveshaft. hope it helps
--Ryan
"The roar of my engine is the song of DOOM to my enemies"
Turbo Cars are like hot women.
A little edgy, every guy wants one, some guys can't handle them
and if you throw a little alcohol in the mix they'll rock your world!!
"Its not hard choosing between right and wrong,, the hard part is choosing the wrong that is more right"
Old 08-15-2003, 09:03 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
One thing could be you have shitty H rated tires, that would most likely happen at those speeds with H rated. Or like Mr2 said it could be a botched wheel balancing.
Question about what causes exhaust noise jessman1128 Engineering/ Technical 3 07-14-2007 11:03 AM
Brake pedal shakes when braking at or above 50 mph? mrtwo Camry/Camry Hybrid/Vista 4 07-03-2005 11:07 PM
