Old 02-24-2002, 09:55 PM
Junie Junie is offline
Unhappy Diesal fuel Error
Help i need to know what would happen if a car got diesel fuel by mistake . my friend thinks he may have put diesel fuel in my car instead of regular what would happen to the car would it have any instant effects what should i do help needed!
Old 02-24-2002, 10:47 PM
texan's Avatar
texan texan is offline
Writer Mod
It won't run at all. Diesel fuel needs a ton more compression to burn properly than gasoline, no spark based ignition system with gasoline levels of compression will cause any meaningful cylinder pressure to occur.
'03 Corvette Z06
'99 Prelude SH
Old 02-24-2002, 11:05 PM
So what your saying texan is that when he turned on the ignition after the fuel was pumped it would not have started . if so then that means he did put regular after all! if so then my car should start up tommorrow morning. Texan you just took a load off my back thank alot a was worried there. again thanks for responding!
Old 02-25-2002, 08:29 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Now if he just put a little in(less than 10%), it may still run but with lots of smoke. You should also be able to smell the distinct paraffin odor. In the "old days" people used to mix diesel with gas every once and a while as a lubricant.
Too much in the tank and it won't run like Texan said. Time to drain the tank and flush the system...
Old 03-01-2002, 11:35 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
not to mention the nozzle for the diesel is completly different the a regular unleaded nozzle.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Got P0601 Internal Control Module Memory Checksum Error replace PCM or RE-Programm? gujju Caravan | Voyager 1 10-01-2010 12:01 AM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 07:37 PM
Fuel Error RudyW Windstar 2 04-10-2008 10:55 AM
Added regular gas into a Diesal fuel tank... sputacus Engineering/ Technical 6 07-30-2005 02:22 AM
P1131 Fuel Error Metering zybecus Taurus | Taurus Wagon 0 05-13-2005 11:34 PM
