AF Premium User
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005
front wheel bearing question
Can you replace just the wheel bearing or do you need to buy the whole assembly? http://www.autozone.com/autozone/par...er=972548_0_0_
#2 | ||
Re: front wheel bearing question
You have to get the hub/bearing as a unit, that's how it's serviced. |
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004
Yup, mine was the complete hub. It also had a pick-up for the ABS tone wheel but the wire was crappy and broke about a year later. Pack rat that I am, I found the old hub, took the stock pick-up from it and installed it on the new hub....still there too.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
AF Premium User
ended up that the bearing was just loose but for $30 bucks we replaced it anyways, it only has about 290k on it. Also found a bad lower ball joint and a missing lug nut, won't be doing business with that tire shop again.
$30 for a bearing? You will be replacing it again....
#6 |
AF - Advisor
