Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 07-11-2012, 10:01 AM   #1
david0715
Missing under load @ low RPM's
Just got back from vacation for a week and the car gave me no problems. It sat for 2 days after that and when I drove it it seems to have a miss under load and sometimes at idle @ low RPM's. The plugs, COP's, and fuel filter have all been changed recently. The car is a 2000 Mustang GT. It driving me nuts.
david0715 is offline   Reply With Quote
Old 07-11-2012, 07:47 PM   #2
danielsatur
Re: Missing under load @ low RPM's
Is the Check Engine Light (CEL) on?
Are there any Diagnostic Trouble Codes (DTC)?
Was the car setting outside when you were on vac?
Could weather, or water be a factor?
danielsatur is offline   Reply With Quote
Old 07-11-2012, 08:08 PM   #3
david0715
No check engine light. I took the car on vacation and had no issues. When I got back on Friday it sat for the weekend. When I fired it up on Monday it had the miss. It was dry all weekend so it shouldn't be water.
Old 07-11-2012, 08:32 PM   #4
danielsatur
Try to get your car to throw a code by driving safe & hard.
If no codes, lets do some tests.
MAF
Fuel pressure
Catalytic converter back pressure test
Old 07-11-2012, 09:17 PM   #5
david0715
Old 07-11-2012, 09:19 PM   #6
david0715
I've tried to get it to throw a code and it just doesn't want to cooperate.i do have a predator tuner that can data log. It will show all the PIDS like fuel pressure and stuff. I just don't really know what I'm looking at when I use it.
Old 07-12-2012, 04:13 PM   #7
david0715
I still have not been able to get a code from it. I don't know how it code miss like this and the computer not see a fault.
As far as the test...what should I look for. I do not have converters on the car. There are MIL elimonaters to on the rear O2's.
Sent from my iPhone using Tapatalk
Old 07-12-2012, 06:15 PM   #8
danielsatur
1) Try to have a local muffler shop do a back pressure test on your catalytic converters for free.
or Google ''Youtube Auto DIY Catalytic converter test''.
If DIY, use a compression tester in place of the upstream H20 sensor instead of drilling hole.
Old 07-12-2012, 10:46 PM   #9
david0715
Would that do anything for me if I don't have converters? I was also told people have been having problems with GMS street fighter coils that I put on my car. Don't know if anyone else has had a problem with them.
Old 07-12-2012, 10:56 PM   #10
danielsatur
Are you using simulators upstream?
Old 07-12-2012, 11:05 PM   #11
david0715
No, the down stream O2's have a jumper between them and the connector. The upstreams are working normally. At least they should be.
Old 07-12-2012, 11:59 PM   #12
danielsatur
Tests:
Catalytic converters - None
MAF - Did you try cleaning Air filter + MAF sensor?
Fuel pressure Test - ?
Smoke Test - ?
Old 07-13-2012, 12:10 AM   #13
david0715
I've cleaned the MAF in the past but I'm sure it could use it again. The air filter is one of those k&n types but I'm not sure how it was cared for before I got the car. The fuel pressure I can look at with my tuner...just not sure what it is supposed to be anyway and I haven't seen any smoke.
Old 07-13-2012, 12:16 AM   #14
danielsatur
We can't rule out a bad or dirty MAF sensor.
Smoke Test - ?
Old 07-13-2012, 07:03 AM   #15
david0715
I'll try to clean that MAF when I get a chance. My fuel pressure seems to stay around 40psi. I don't know what it does when I'm driving, I'll have to check when I get out of work. The car seems to take off fine as long as the revs stay above 2K. I only really see the problem when I am trying to accelerate moderate to hard in a high enough gear that it keeps my revs under the 2K mark. The farther below 2K, the worse it is and then seems to clear up.
97 Chevy s10 miss under load metalman55 Problem Diagnosis 31 05-11-2015 11:19 PM
Jeep misses under load.. solution tagger Grand Cherokee | Grand Cherokee SRT8 0 01-22-2005 11:20 AM
5.7 missing under load. Out of ideas..HELP LastOne C/K 7 03-21-2004 10:52 AM
Missing under load FordInPossession Crown Victoria 6 01-08-2004 06:43 PM
Engine misses under load RansomEli C/K 1 11-18-2003 06:08 PM
