Old 07-01-2012, 02:29 PM   #1
babsb67
Red face Z24 Ran out of gas and won't start
Yesterday my 2001 Z24 ran out of gas. I put approx. a 1/4 tank of gas in it and now it will not start. I can hear the fuel pump humm. Tried starting the car numerous times it sounds like it is going to turn over but it won't. I need help asap because I need my car tomorrow to go to a Dr.'s appt. Thank you in advance for your help.
~B~
babsb67 is offline   Reply With Quote
Old 07-01-2012, 03:05 PM   #2
Tech II
Re: Z24 Ran out of gas and won't start
Get a can of carb cleaner and spray it into the intake.....then try and start the car......if it runs as long as you spray, then it is a fuel problem.....either the injectors are not firing or you have no fuel pressure.....if there is a shraeder valve on the fuel rail, depress it and see if fuel shoots out....if nothing or a trickle, then most likely the pump....just because you hear the pump, doesn't mean it is pumping....
One thing I harp on......never run a vehicle under 1/4 of a tank.....if you constantly do, you are asking for problems....that fuel pump gets very hot.......the gas covering it, keeps it cool.....you will will shorten the life of the pump this way....
Old 07-02-2012, 10:36 AM   #3
babsb67
Thumbs up Re: Z24 Ran out of gas and won't start
Thank you so much for the info. I put a half tank of gas in and it started and runs. Only problem is, it is running very rough! Thank you for the advice about the gas pump.
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
99 Rodeo ran out of gas, now won't start bdzb1234 Rodeo | Passport | MU 7 01-16-2009 11:30 AM
ran out of gas now won't start !!!! w8 4me Grand AM 2 05-12-2007 12:38 AM
92 PA - Ran out of gas, now won't start spelljunkie72 Park Avenue 2 11-01-2005 05:19 PM
Ran out of gas know won't start scuba4321 Cherokee 3 09-01-2005 11:24 AM
