Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-05-2012, 09:40 PM
89crown 89crown is offline
Smile car is not firing and wont start
I have a 1989 cutlass Ciera with 3.3 v-6 and when you turn the engine over it appears to be not firing and it want start. Can you tell me how to fix this car where it will fire again so it will start again. Thanks
Old 07-06-2012, 07:23 AM
maxwedge maxwedge is offline
A990 racer
Re: car is not firing and wont start
No magic answer here, do you have spark at the plugs, will it start by spraying carb cleaner into the intake, you have provided no info here.
Old 07-10-2012, 04:24 PM
No the car was running but in need of a tune up, so i pull one of the spark plug wires off to check its condition, and forgot that i took it off and started up the car to pump my tires up and the metal plug cover was popping due to it was laying beside the heat sheild so i heard a tapping sound so i cut the car off, and reinstall the plug wire and it haven't started since, so what can i do to get fire back so the car will start again. Thanks
Old 07-10-2012, 07:26 PM
A990 racer
Ok no spark, check the fuses, if ok, it could be the ign module or the crank sensor, or the wire from the icm to the crank sensor. The procedure to do this can be found at autozone.com, repair guides.
Old 07-10-2012, 10:20 PM
grease_monkey1975's Avatar
grease_monkey1975 grease_monkey1975 is offline
I believe you have a distributor on that car? If so you could have done some damage to it with the plug out ,check you cap for arc jumping and make sure your dist is working properly
Old 07-11-2012, 06:28 PM
Tech II Tech II is offline
Pretty sure it is DIS.....
Old 07-11-2012, 06:43 PM
A990 racer
Thumbs up Re: car is not firing and wont start
correct.
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
Car Will Crank But Wont Start And Stay Running kmccraney Cutlass Series 2 11-28-2006 02:04 PM
92 2.2 Cavalier not firing and fuel pump not running peewee2 Cavalier Problem Diagnosis 2 03-07-2005 08:36 PM
Car Still will not fire, and cannot get any code Lotus49 Camaro Discussions 1 08-05-2004 06:52 PM
