Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 06-20-2012, 02:36 PM
gregguy gregguy is offline
2003 engine stutters and or stalls on hwy.
hello, my 03 windstar has a jerking or stutter at hwy speeds. Sometimes it will stall while doing 60-70 mph, It will not start in neutral, have to do a complete stop in order to reststart motor. This is dangerous stalling on hwy's with no shoulder to stop on. I have changed a blocked fuel filter and though it runs better, hwy stalling still occurs. When jerking happens, if i let off gas quickly, sometimes prevents the stalling. This has me worried for my safety. Any ideas would be much appreciated. p,s, codes 171,174 are on, but think tsb 13-6-1 would fix that. thx.
Old 06-21-2012, 11:56 PM
wiswind wiswind is offline
Re: 2003 engine stutters and or stalls on hwy.
There are a LOT of things that can cause this.
You should be able to start the vehicle in neutral.......which makes me wonder about the Neutral Safety Switch (AKA Transmission Range Sensor).
Check for any signs of a vaccum line being off.....
Super check the hose from the PCV valve to the intake manifold.....years of exposure to the oil vapors can soften that.
Also verify that the line from the flex hose to the rear valve cover (1999 and newer windstar) is intact.....if that is disconnected at either end....that is a huge vaccum leak.
Those are the cheap & easy things that come to mind.
If the stalling is only when you remove your foot from the accellerator, the most likely cause is the Idle Air Control valve (IAC).
There are posts on here as to how to clean it.
The IAC controls the engine speed when your foot is not on the accellerator.
There is a little motor that drives a shaft with threads on it (like a screw) that moves a valve open and closed.....and if it is sticking, then you will have stalling issues when your foot is not on the accellerator.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
The Following User Says Thank You to wiswind For This Useful Post:
gregguy (06-25-2012)
Old 06-25-2012, 11:44 AM
Thanks for responding, no, stalling only happens when gas pedal is pushed. In fact sometimes when accerating off stop or light, motor stalls. also feels sluggish at hwy speed. I am wondering if the fuel pump might be going. Is there a way to test this while still parked. If its the fuel pump, will that not restart in neutral. think I heard something about ignition switch starts fuel pump. It really does feel like its sometimes starving for gas. thanks.
Old 06-25-2012, 12:01 PM
danielsatur danielsatur is offline
Air - Do a smoke test
Fuel - Do a fuel pressure test
Exhaust - Catalytic converter back pressure test
Does Heat play a factor?
Is the CEL on? yes
Fix the unmetered air leaks 1st
Old 06-25-2012, 02:15 PM
12Ounce 12Ounce is offline
Fuel pump!
2003 engine stutters and or stalls gregguy Windstar 1 05-25-2012 10:05 AM
Engine Stuttering and Turn Signal Blink Rate jzeyer Grand Marquis 2 06-20-2005 10:08 AM
91 525i Engine Stutter and Hesitatation DynoDuckfart 5 Series 1 02-15-2005 01:14 PM
87 dodge van b250 stutters and stalls drachewolf Ram Van 2 01-02-2005 08:22 AM
G94 Grand Am Stuttering and stalling NicelowZ Grand AM 0 11-25-2004 06:31 PM
