Go Back   Automotive Forums .com Car Chat > Ford > Ranger | Courier
Old 02-15-2012, 12:00 PM   #1
buffercat
Lights flickering low beam only
2007 Ranger DRLs are flickering as well as low beams, driving lights are good as are the high beams . Could this be the drl module doing this and where is it located. Can it be tested ?
buffercat is offline   Reply With Quote
Old 05-22-2012, 09:47 AM   #2
lectraplayer
Re: Lights flickering low beam only
That sounds like a loose connection somewhere upstream of the DRL. Try tracing everything from the DRL to the fuse box. The fuse may even not be sitting in tightly. A Haynes manual may help here.
lectraplayer is offline   Reply With Quote
Old 05-22-2012, 05:09 PM   #3
buffercat
Sorry I didn't update, found bad connection at the plug, repaired and all is good.
Already tried some things, but still: Only high beam, no low beam bramcc Tracker 4 11-08-2007 08:35 AM
93 Camry Lights dimming low/flickering nick bamberger Camry/Camry Hybrid/Vista 3 01-19-2006 07:32 PM
95 Max Dash lights flicker hi / lo when hi beams on. BCMaxima Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-30-2005 01:59 PM
Hi beam light on with low beams pknapp Ram Pickup | Ram SRT10 3 11-09-2004 12:00 AM
81 High beams only, power to low beams wristman Monte Carlo 3 10-23-2004 09:17 AM
