Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-06-2012, 07:55 PM
louess louess is offline
Flashing OD light
Has anyone found a reason why the OD light flashes, and how to fix it with out spending an arm and a leg?
Rushing, sorry forgot details. Light flashing on a 99 ford Explorer.
Last edited by shorod; 02-06-2012 at 10:22 PM. Reason: Two threads by the same author that feed off of each other.
Old 04-02-2012, 07:03 PM
bigryry bigryry is offline
Re: flashing OD light
In mine, which is an 02 which was the new style for the 4 door, i needed a new transmission. 1700 bucks for a rebuild. Get the code read at a trustworth transmission place. I found most general mechanics didn't read those codes and the dealer sent their transmission out to a local shop anyway.
Old 04-02-2012, 07:43 PM
FishFind FishFind is offline
One Hot Shot
YES CHECK YOUR FLUID LEVEL.
Truck need to be warm ran through all gears and on flat surface check level. If low find out why it is low don't just refill.
You will kill this tranny if you drive it like that.,
Old 04-03-2012, 04:48 AM
DeltaP DeltaP is offline
Find yourself a reliable transmission shop. Good luck finding the tranny dipstick... there is none.
Seat belt light on - code 32? tkswan LS | MKZ 3 02-07-2012 11:33 PM
