cooling issues
I have a 2000 rodeo that I just put a new timing belt and water pump and thermostat. It does not over heat but it is blowing coolant out ove the overflow and the pressure on the hoses seems really high. I was looking to see if anyone has had this problem and what I can do?
Dave 2000 rodeo ls ,3 ind. off road lift, 31" geo-landers rancho 9000/s 72' 1200 hd custom (money pit!) 03' suzuki aerio sx 07' suzuki sx4 awd ( best bang for the buck ) |
Isuzu Guy
![]() Join Date: Jan 2004
Re: cooling issues
Change your radiator cap ...
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Re: cooling issues
You need to get the air out. Remove the radiator cap and squeeze the hoses until the air bubbles stop. Sometimes rocking the car side to side will help dislodge air bubbles.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs. 03 GMC Envoy XL SLT 4x4 5.3L V8 |
Re: cooling issues
Its has a new radiator cap and I did the steps on removing the air form the system. After I get the air out its fine for about 3 days. Then it starts burping into the overflow. After that it just gets worse. But I get hot air from the heater all the time with out any cold shots. The thing just builds pressure for some reason. No oil in the fluid or fluid in the oil. No leaks anywhere. And it runs normal temp.?
Re: cooling issues
Well Thanks for the tips all. I found out the problem it was and is a head gasket. Lovely?
It tested positive for hydrocarbons in the coolant.
