Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 11-16-2011, 02:50 PM   #1
buckiejr
Question 2000 Chevy S10 2.2l pickup
i changed the spark plug wires and plugs on a 2000 Chevy S10 pickup now it runs will bad sound like the pipes fell off
buckiejr is offline   Reply With Quote
Old 11-17-2011, 07:07 PM   #2
FishFind
One Hot Shot
Re: 2000 Chevy S10 2.2l pickup
re word that. That is bad English.
FishFind is offline   Reply With Quote
Old 11-24-2011, 12:25 PM   #3
trox
The first thought I have is you have 2 of the 4 wires crossed. On a 4 cylinder, that can make a huge difference. Double check your work there. Then if that's good, you need to find the cylinder or cylinders that aren't firing. You can get to the 2 3 and 4 plugs fairly easily. If you pull the plug wires off and push them back on enough to make contact but not snap on, start the engine to make sure you have what you had before with bad performance. Now you can carefully, preferably with some rubber covered handled pliers, pull the wires off 1 at a time and see which wires are keeping you running. If it dyes or gets worse when you pull a wire, that cylinder is working. When you find the cylinder that's not working, check the plug to make sure you didn't crack it on install and make sure the wire is good. If you still have the old wires you could swap one back in to verify. good luck and let us know what you find.
trox is offline   Reply With Quote
Old 11-24-2011, 01:36 PM   #4
maxwedge
A990 racer
Wink Re: 2000 Chevy S10 2.2l pickup
Yikes you translated that , well done.
1999 Chevy S10 2.2L Hesitation probs kmcbee S-10 11 05-26-2008 05:11 PM
2000 chevy s10 w/2.2L RainXRules S-10 3 10-24-2005 03:56 PM
Chevy s10 2.2l...hp gains KluTch89 S-10 5 09-24-2005 08:59 AM
95 chevy s10 2.2l seym0rebutz S-10 1 08-30-2005 09:58 PM
95 chevy s10 2.2l mods seym0rebutz S-10 1 08-28-2005 06:59 PM
