Old 05-30-2003, 02:53 PM
blade34609's Avatar
blade34609 blade34609 is offline
SOHC VTEC head
Hi,
I have a 90 Civic LX with the D15 engine and I read about someone swappign a SOHC VTEC head onto their engine.
Its supposed to give between 115-120hp which is pretty good instead of the costly engine swap.
How hard is it to put a new head onto the engine block?
What else will I need for this swap?
Is it the cylinder head?
I went to car-parts.com and they have the option for Head(cylinder) is this the one?
Thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 05-30-2003, 03:15 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
the SOHC VTEC head swap, commonly called "mini-me" is a very easy swap. Keep in mind, however, that you will also have to convert to MPFI, because your DX injection system (DPI) is very weak and not performance oriented.
As far as the head swap is concerned, however, unbolt your head off the block, remove a small oil squirter (bronze colored thing in the middle of the block, its a small circle with a hole in it, just pulls right out), bolt on the VTEC head and thats it. You'll have to find a way to activate VTEC, rpm activated switches, VTEC controllers, or OBD1 conversion are some of your options.
as for the MPFI conversion, you will need a 4thgen Si Intake manifold, throttle body, fuel injectors, fuel rail, and all sensors, basically a complete intake manifold assembly. A 5th gen manifold can be substituted, but some vacuum line and wiring changes must be made. if you are confident with your soldering skills and wiring skills, here is a small diagram.
enjoy VTEC.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 05-31-2003, 04:04 PM
91BLKsi 91BLKsi is offline
Send a message via AIM to 91BLKsi
I wanna do that for my si...umm....what to do for oil passages?...how do i put oil in it??..I already know how to wire the siliniod..Imma wire it to my tach light and set v-tec at 4500...so i know when it kicks in..heheheh
Old 05-31-2003, 04:09 PM
Old 05-31-2003, 07:18 PM
I know..but how do u put oil in on the other side?......because on my mototr the oil cap is on bottom left and soch head oil cap is on the top right
Old 05-31-2003, 07:20 PM
lol
it doesnt matter where you put the oil in, it all drains down into the oil pan anwyays.
Old 05-31-2003, 07:22 PM
oh..heheehehe...so the head goes rite on??...I got a 95 si head
Old 05-31-2003, 08:23 PM
yes it will bolt right on, butmake sure you remove the oiljet. you will see what im talking about when you take your head off. in the middle of the block, i belive on the back side, theres a little bronze colored circle witha hole in the middle of it.. it comes right out, make sure you remove it. Use a d16z6 head gasket, and it is recommend that you get a 92-95 VX timing belt, but i belive that i used the stock 1.5L timing belt, but im not 100% sure.
anyone have any info on a f22a non-vtec head swap to a f22b sohc vtec head mox4_2001 Let's get Technical! 3 06-27-2004 08:46 PM
Sohc Vtec head 2 A Non Vtec Block lowcivicman99 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 06-25-2002 07:31 PM
Sohc Vtec head 2 A Non Vtec Block lowcivicman99 '71-'87 Civic | CRX 1 06-25-2002 12:43 AM
? about Mini-Me Sohc Vtec Head Phat_Si Engineering/ Technical 5 03-18-2002 09:45 AM
