Old 10-04-2011, 03:01 AM
camaro22 camaro22 is offline
1995 Chevy Camaro v6 3.4l overheating problem
my 1995 chevy camaro has been overheating. at first i thought it was the thermostat sticking because there was no spewing or smoking so i changed the thermostat and my car was still over heating. I finally found out that the water pump was leaking fluids. so I changed out the water pump and filled it full of coolant. i turned on my car and within 10 minutes the gauge went up to 260 degrees and went down a little bit but stayed around 260, there was no spewing or leaking or smoking again. I was thinking that maybe now it could be the sensor but im not sure. what else do i need look for. please help.
Old 10-04-2011, 10:24 AM
Tech II Tech II is offline
Re: 1995 Chevy Camaro v6 3.4l overheating problem
Did you check the lower intake gaskets for leaking.....did you check the corners of the heads for leaking(could also be leaking internally, and burning up in cylinders)....
Did you properly bleed the air out of the system? If you didn't, this would cause an air pocket....
Are you getting heat out of the heater core? If no, then it could be plugged or air bound.....
1996 Monte Carlo Z34/ Cutlass Supreme 3.4L Idle Learn Procedure 96cutlass3.4 Monte Carlo 0 06-17-2010 11:43 PM
94 Camaro 3.4L starting problem dksob81 Engine and Transmission 6 02-24-2009 12:22 AM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 04:27 PM
1995 Cutlass Supreme 3.4l lock problem dTicK09 Cutlass Series 6 11-12-2008 04:12 PM
1995 camaro 3.8 heater problem jhousman6 F-Body Problem Diagnosis 3 02-08-2007 07:04 PM
