Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 11-27-2010, 04:13 PM
AlphaCrow AlphaCrow is offline
05 Liberty Water pump gasket leak, 2 gaskets later
Hey all, '05 Liberty. Started leaking near the 3rd bolt to the right (from top) on the water pump. Took it apart, the gasket had a bunch of crud (dried coolant) on it. Cleaned it very well with a nylon brush, put a new gasket in. ..................................... . Months later, leaking again from same spot. Took it apart, gasket looks clean. I put thread sealer on the bolts and some RTV gasket maker on the outter edge of the gasket, bolted it, came back and retightened to torque specs. . ............................................ Leaking again a few months later. Same spot. I think it leaks when it's cooling after being hot during normal driving, cause it only seems to leak in the driveway, then will seal up again. Any ideas? Pump works. Coming from the gasket area (as best I can tell). I put some flour on it once and the trail of water came from that area. .................................................. .. . . Metal cracked? Bolt hole bad? Surface is pitted? Since everything is working fine, except for the leak, should I put some more RTV in there and just try to plug the leak?
Old 08-15-2011, 05:51 AM
Jamesjjr9110 Jamesjjr9110 is offline
Re: 05 Liberty Water pump gasket leak, 2 gaskets later
Apparently from what I've read. These Jeeps are known for overheating. The water pump could be warped. Might check for that next time. I got someone bringing me theirs and its leaking in EXACT same spot... After it over heated ... I'm debating if I should go ahead and replace whole water pump and gasket on theirs just to be safe... Along with thermostat. I've heard these Jeeps are nothing but problems
Cars I've owned oldest to newest:
89 Plymouth Voyager 3.8 v6 Stock 210k?
91 Buick Lesabre 3.8 V6 Stock 147k
91 Ford escort 1.9 I4 Stock 140k
94 Chrysler Lebaron 3.0 V6 Stock 155k
98 Dodge Caravan 3.8 v6 Stock 180k
00 Ford Crown Vic 4.6 v8 Stock 90k
Notice they are ALL American?
Old 08-19-2011, 08:47 AM
I ended up replacing it. You're right, it was warped and would move around during heating and cooling. New after market one works good. This jeep has been falling apart since we bought it. Tranny just cratered recently. Never buy modern jeep.
How to change gasket on cross pipe at rear of engine cmar2112 Trooper | SLX | Bighorn | Wizard 1 04-22-2010 12:50 AM
Head Gasket Leak el ratfink General Discussion 4 08-14-2009 07:04 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 02:17 PM
Water pump keeps leaking, was just replaced a_alyte Grand Cherokee | Grand Cherokee SRT8 4 07-15-2008 08:51 AM
lt-1 new water pump leaks: cheap gaskets? FormulaForce F-Body Problem Diagnosis 2 10-01-2007 08:26 AM
