Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 06-12-2011, 11:06 PM   #1
White_Stang_2006
Air Condtioning Problems
I have a 2001 Mustang V6; 3.8L and I am having problems with my air condition. When I start my engine and turn on my air condition, it initially blows hot air; and then after a minute or two, the air cools down to a cooler temperature, but not as cold as I like it! Also, if I am sitting in traffic or idle, when the air condition is on, my temperature gauge goes toward the "H", like my vehicle is about to run hot. So, I have to turn the air condition off, so the car can cool off. Someone told me, that I need to buy a thermostat and have the anti-freeze and coolant flushed and refilled, and maybe that will stop the problem. Does that sound like that will help? Or do any of you guy know what the problem might be?
White_Stang_2006 is offline   Reply With Quote
Old 07-31-2011, 09:30 PM   #2
mustangmike351c
Re: Air Condtioning Problems
see if the fan is turning fast with the a/c on. make sure you dont have a low voltage problem. your other post sounds like a bad alt
mustangmike351c is offline   Reply With Quote
Old 08-14-2011, 02:33 PM   #3
HiFlow5 0
Stanger
HiFlow5 0's Avatar
Send a message via AIM to HiFlow5 0
Have you found your AC problems yet? There are two separate issues here. The AC operation and the engine temperature. First thing is the fan should have 2 speeds, with the AC on you should notice a difference in fan speed which is controlled by the AC cycling switch. Second, you should have your AC system looked at, if it's blowing cool, not cold, then you either have a leak or a unplanned restriction in the system.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
HiFlow5 0 is offline   Reply With Quote
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 09:49 AM
air condtioner problems for a chevy impala nelbernie Impala | Impala SS 1 09-12-2008 08:43 PM
2000 Nissan Xterra Air Condtioning Problem ALLEN MARTIN Introductions 1 10-05-2005 09:07 PM
Air Condtioner gets hot when idleing.....HELP!!!! furiouscav Cavalier 3 07-09-2003 11:27 PM
Ball Joints? / Air Condtioner n00b666 Eighty Eight 0 03-13-2003 11:22 PM
