Where is the A/C drain hose
I'm sorry I'm not sure what it's called but where is the drain hose that let's the A/C condensation drip? I think mine is plugged because my condensation is leaking into the cab on the passenger side. It only happens when the A/C is on. I want to try to clean it out...if I can find it.
It's a 2001 Ram 1500 5.2L. Thanks, -mark
Mark "Sharky" Stover 73 Century Regal 455 05 Chrysler T&C 07 Dodge Ram SLT 11 GMC Yukon Denali XL |
Re: Where is the A/C drain hose
On the passenger side of the engine compartment, behind the accumilator (round tank looking doodad with AC lines connected) sticking out from the firewall about an inch is a piece of black tubing, about 1" OD. Condensation from the AC comes out of the piece.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
Thanks. I found it but it doesn't appear to be plugged. I stuck a coat hanger in it anyway and also used a shop vac to suck anything out.
