Go Back   Automotive Forums .com Car Chat > Chevrolet > Venture
Old 06-27-2011, 01:40 PM   #1
venturenot
Screws, nuts & bolts for Chevy Venture
Can anyone tell me what type of screw holds the throttle position sensor into place. Also, where can I find this information on my own. Is it possible to purchase a bag of screws nuts and bolts that will fit the Venture or can these screws etc. simply be purchased from Home Depot?
venturenot is offline   Reply With Quote
Old 06-28-2011, 08:04 AM   #2
sverker
Re: Screws, nuts & bolts for Chevy Venture
I'm not sure which is the size of the screws for the throttle position sensor as I haven't taken away mine from the throttle body but all screws I've seen so far on this engine have been metric. I would guess M4 or M5 for the sensor or maybe as small as M3, but you would need to measure the length as well and if it has any special shape. Here in Sweden I can find standard shapes in any good hardware store.
sverker is offline   Reply With Quote
Old 06-28-2011, 01:40 PM   #3
rhandwor
Remove one and go to the Home Depot ask for help they can get you some that will work. If they have a head where a torx bit is needed you can use allen head bolts.
I assume you lost one. You can also go to a yard like Pull Apart and remove a couple.
I do this for expensive odd size bolts.
rhandwor is offline   Reply With Quote
The Following User Says Thank You to rhandwor For This Useful Post:
venturenot (07-04-2011)
Old 06-28-2011, 08:06 PM   #4
venturenot
Problem is that I am traveling and do not have an extra car to use. I was hoping someone knew the size screw so I could go to home depot and get an extra. I haven't lost one, but I would like to have an extra just in case. The lower screw on the tps sensor is hard to get at and I'm afraid I will drop it.
Old 06-30-2011, 09:52 AM   #5
sverker
I checked on mine, the diameter of the screw is 4 mm so it's probably a M4 and length is 13 mm.
The Following User Says Thank You to sverker For This Useful Post:
Old 07-04-2011, 10:19 PM   #6
venturenot
Thanks much for the size. Is it OK if I replace the torx screw with a phillips head that is a little shorter - 12mm. Just a question because it really doesn't matter now. I replaced the tps sensor without dropping a screw. It was a lot easier than I thought because the sensor is held in place with out the screws. Anyway,job is done and I am happy. Again just a question, if I had a problem would a phillips head that is m4 12 mm be Ok, or do these screws have to be precise. Thanks much.
HUGE Wheel Lock nut issue! Need help finding the right key/socket to fit! Passatguy Tires and Wheels 4 09-01-2010 12:46 AM
Metal nut & bolt aftermarket kits? IndianJim Car Modeling 9 07-18-2006 04:45 AM
00 GA Snapped off lug nut & intire Bolt! peteyboy310 Grand AM 3 01-21-2006 02:39 PM
Correct Nuts & Bolts? DIGITRUCK Cherokee 5 01-17-2006 06:25 PM
How to install remote starter & alarm for 97 venture ? chuasam Venture 6 06-17-2005 09:08 AM
