Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 06-12-2011, 11:11 PM   #1
White_Stang_2006
Electrical Issue
I replaced my car battery in June 2009 and again in December 2010; since the new batteries has been installed, I have had electrical issues with my vehicle. The interior and exterior lights flicker and the engine does a humming noise in harmony of the lights (exterior and interior) flickering. Does anyone know the cause of this issue?
White_Stang_2006 is offline   Reply With Quote
Old 07-31-2011, 09:26 PM   #2
mustangmike351c
Re: Electrical Issue
Its the alternator.
mustangmike351c is offline   Reply With Quote
Old 08-14-2011, 02:36 PM   #3
HiFlow5 0
Stanger
HiFlow5 0's Avatar
Send a message via AIM to HiFlow5 0
Why did you replace the batteries? That type of issue sounds to be an unplanned electrical draw. As mentioned above it could be the alternator. A quick flat rate method to test this is, whicle the vehicle is cold, turn the ignition on, but do not start. Let the vehicle sit for a few minutes and then place your hand on the alternator, if it's warm to the touch then chances are you have an internal regulator issue on the alternator drawing excessive current.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
HiFlow5 0 is offline   Reply With Quote
01 Jimmy 4WD Strange Electrical Issue chobes Problem Diagnosis 3 12-29-2010 12:55 PM
New electrical issue Malacite69 Cavalier Problem Diagnosis 0 03-09-2010 03:33 PM
2001 ZR2 electrical issue airboss20 Problem Diagnosis 4 12-26-2009 08:59 PM
1998 Passat Electrical Issues mns247365 '97+ 2 05-22-2009 01:36 PM
2001 cav electrical issues Raeven Cavalier Problem Diagnosis 0 04-29-2009 10:23 AM
