Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 04-27-2011, 06:21 PM   #1
jojo32
4T60E Tranny troubleshooting.
hello, im new here in desperate need of help!95 grand am 3.1 with 4t60e tranny has 126000 miles. tranny shifts fine sometimes then other times wile im accelerating it slips, rpm's fly up and it takes 10 sec with foot off of gas for it to catch( almost like its in neutral). Problems getting worse with time. Only 2 codes ignition switch( Which i replaced so i think the code is old) and vss which i replaced yesterday, vss made no difference and mph gauge is still jumping around reading crazy. fluids are good. I think there is a vacuum leak somewhere i could hear it. When I first put it on the road 2 months ago problem wasn't as bad as now. At 60 mph it would vibrate violently. I unplugged the main plug on top of tranny and vibration stopped, I drove it for a day like that until I learned it was not shifting at all then I replugged and vibration is mysteriously gone but still have a very bad slipping problem. I think the car starts in 2nd gear. Any advice would be great, thanks... Does anyone have a diagram of the vacuum lines threw out the car?? Is there a way I could disable the tcc silonoid to check for that??
jojo32 is offline   Reply With Quote
Old 06-03-2011, 06:20 PM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
Re: 4T60E Tranny troubleshooting.
Welcome to AF and sorry for the late reply!!
First I'd find & fix that vacuum leak, could be causing your troubles.
Also had the car been sitting for a long time and not driven ??
If so, I'd try a fluid & filter change to see if that helps.
I'll see if I can find this link to a transmission site with testing procedures so you can test the TCC, it to might be the culprit. You might need to take it to a trans shop and let them scan it for codes.
Found these two links that might help.
http://www.atraonline.com/manuals/ge.../tetdv-c3g.htm
http://autorepair.about.com/cs/doity.../aa011703a.htm
Hope that helps !
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
95 Bonneville, 4t60e Tranny...code 740 jasoninva Bonneville 2 04-11-2007 11:14 AM
4t60e Tranny Out Or?????????? GUNNER01 Grand AM 1 12-12-2005 02:08 AM
2000 pontiac 4t60e tranny problem hotwheel42 Grand Prix 2 03-07-2005 09:44 PM
F/S~ 4T60e tranny and Misc eng parts Loudz34 Grand Prix 0 08-06-2004 11:51 PM
Tags
3.1 , diagram , tcc , transmission , vacuum
