Go Back   Automotive Forums .com Car Chat > Mercury > Cougar
Old 04-26-2011, 09:05 PM   #1
that_one_guy
Unhappy I can't get the brakes on my car to work!
1996 cougar
4 wheel disk brakes-ABS
Im having a problem with my brakes . I can get the front brakes to work but not the back . The pedal feels like it goes farther down then it should before i stop. i bought new master cylinder, front and rear calipers, proportional valve, and flushed the system . pedal is hard when i start, but after i bleed the screw it takes 1-2 minutes before i get pressure again . Pressure will stay and no sign of fluid is leaking except "VERY" small leak on brake line. What could this be??????
that_one_guy is offline   Reply With Quote
Can't get Gas Gage to work Derek44 Problem Diagnosis 1 04-06-2010 10:06 AM
Can't get the brake rotor to come off vgames33 Engineering/Technical 4 10-26-2008 05:31 PM
I can't get the water pump pulley/casing to seperate from the water pump. mikev08826 Grand AM 4 03-06-2005 04:00 AM
Speedometer doesn't work.. can't get the pin into hole behind the gauge 90gs Integra 5 05-20-2003 11:40 AM
