Rough idle, runs rich. Floor the gas pedal smooths out.
I got a 91 ranger with 2.3 8 plug system. To start off. The truck was losing power and so i decided to change plugs on it drivers side. I knew the ones on passenger side were good. So i had to take the upper intake off to get to the last 2 plugs. So i did all that and put it back together. When i started it up it ran awful. Runs rich can smell it through exhaust. Motor shakes due to miss. It. Barely idles and sometimes pops through throttle body like a backfire. If i give it some gas about 3,000 rpm's it smooths out. I replaced the tps. Had 2 bad vacuum lines replaced them. Has new plug wires. I think its the air idle control but not sure. Its $93 new so i just dont want to buy it and that not be the problem. Any other suggestions
software a new product
this is the newest product.
<a href=“http://www.indigitalworks.com/EBooks-with-Private-Label-Rights-Silver-Membership/”>indigitalworks</a> http://www.indigitalworks.com/EBooks...er-Membership/ |
Re: Rough idle, runs rich. Floor the gas pedal smooths out.
My guess is you are leaking vacuum through the intake manifold you took off or have a vacuum leak somewhere else. The fact that is got worse after taking off the intake manifold might be a clue. good luck
