| Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
Wheel Question
If two cars have the same bolt pattern and rim diameter is the same, is the hub also the same? I ask because I went to put a wheel from an 84 caprice on a 74 pontiac catalina and the wheel wouldn't go over the hub. From what I've read they share the same bolt pattern.
Thanks |
Re: Wheel Question
The center hub bore on the wheel is smaller than the hub on the car. You would have to shave that bore bigger to fit. Same concept as putting a Chevrolet Silverado wheel on a Nissan Titan, the hub is different on the Titan. But the Titan wheel can fit the Silverado.
1999 GMC Sierra RCSB 4.3L V6 overall stock plus some exterior and interior work. |
| The Following User Says Thank You to slo99sierra For This Useful Post: |
kris (02-11-2011)
Re: Wheel Question
Ok thanks. Good thing I never caught a flat while using this wheel as an alternate to the tiny doughnut.
Is this variation something you see on factory wheels mostly? When I look for wheels on craigslist, you usually only see bolt pattern and I''ve bought based on that with no problems before. Last edited by moliva1568; 02-09-2011 at 03:15 PM. |
#4 | ||
Re: Wheel Question
The RustBuster
![]() Join Date: Feb 2006
Re: Wheel Question
Most reputable AM wheel manufacturers would be able to tell you if their wheels would fit a particular vehicle/model...places like Tire Rack consolidate all the info from them to tell you what will fit. The hub hole diameter should be listed in the wheel's basic info along with the bolt pattern.
Hope this helps.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Re: Wheel Question
Most of the times the wheels do fit but cause balancing issues. I rode with a rented car driver and he put a smaller wheel than normal in Toyota Platz and it worked fine except for some balancing and handling issues
#7 | ||
SHO No Mo
![]() Join Date: Jun 2004
Re: Wheel Question
-Rod |
