Go Back   Automotive Forums .com Car Chat > Cars in General
Old 08-24-2003, 01:24 AM   #1
GenoPhillipe
Question Power window "sticking", Help!?!
The driver's side power window "sticks" on the way up. the window motor is fine. I've cleaned the glass several times and tried to clean the weather stripping. any other ideas? are there weather stripping cleaners/lubes?
GenoPhillipe is offline   Reply With Quote
Old 08-24-2003, 03:20 AM   #2
BullShifter
BullShifter's Avatar
Try using silicone
What kind of car?
BullShifter is offline   Reply With Quote
Old 08-24-2003, 12:09 PM   #3
Steelrat
Silicone should help for now, but you'll probably have to keep applying it. There are probably other channels inside the door which could use a cleaning and lube if you havent done them allready. When your window is attempting to go up do you hear the motor working. Lots of regulators or motors I have replaced due to just being weak. There are so many different styles of window systems, you would have to be specific, there are plastic cable, metal cable, gear, direct linkage, hook ups from the motor to the window in many different cars.
Steelrat is offline   Reply With Quote
Old 08-25-2003, 12:53 AM   #4
GenoPhillipe
At the risk of sounding like a complete idiot. Can you recommend a brand of silicone? Wouldn't that leave a smear on the window? Thanks for the advice.
Old 08-25-2003, 01:05 AM   #5
BullShifter
I think the stuff we use is made by Pyroil - you can find silicone lube @ any auto parts stores. It will smear if applied heavy, only a thin layer is needed - wipe down with a rag. Like steelrat said your regulator is probably on its way out.
Old 08-25-2003, 02:39 AM   #6
BigDanTheMan
I read and am helpful.
BigDanTheMan's Avatar
Send a message via AIM to BigDanTheMan
even though you think your motor is fine, there still could be a problem - like gear slippage, perhaps some of your teeth are worn.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
BigDanTheMan is offline   Reply With Quote
Old 09-01-2003, 03:02 AM   #7
Boxchevyondubz
It's possible that you may have something obstructing the track, your best bet is to remove the door panel, and with the window down, go throught the track to assure nothing is preventing the window from operating properly. If the window has been broken, a piece of glass will easily prevent it from raising and lowering smoothly, but you'd most likely hear a scratching sound when moving the window.
Boxchevyondubz is offline   Reply With Quote
Old 01-28-2011, 11:15 PM   #8
mabawa
Re: Power window "sticking"
I have a 1967 Olds 442 convertible with power windows. I have had all the window motors replaced and the windows aligned. However, they tend to stop working on a regular basis. The last time I took the car back to my window/electrical guy, he said the problem was that the windows stick if raised completely. He said he had to free them with a rubber mallet they were so tight. He also said that the only solution was to drop them a bit after raising; that no lubrication would work. This of course is rather inconvenient in the rain.
I know this is an old car and the channels can get a little bent over time. But I am perplexed that proper alignment and lubrication does not eliminate this problem. I raised the matter with my body shop and they were just as perplexed.
Anybody have any ideas or comments.
Thanks. Mabawa
mabawa is offline   Reply With Quote
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 02:44 PM
power windows stopped working - 2002 Mercury Mountaineer hoehring Mountaineer 2 01-18-2010 10:25 AM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 11:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 07:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 12:48 PM
