Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 01-17-2011, 08:38 PM   #1
Andyman150
Sitting car wont start
ok, my car has been sitting in the garage for almost 2 years now. I left it with a 1/4 tank of gas without putting fuel stabilizer in it. Now that its time to get the car back out I bought a brand new battery (the last one wouldnt hold a charge), oil and filter, and some Lucas injector cleaner to add with some fresh gas in hopes that it mixes with the old and turns. well I did that and when i turn the key it just keeps turning. It doesn't fire or turn over. So now i wonder if its a fuel pump or ignition problem. HELP!
Andyman150 is offline   Reply With Quote
Old 01-17-2011, 10:35 PM   #2
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Sitting car wont start
What year/model/engine?
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
Old 01-18-2011, 12:27 AM   #3
Andyman150
2000 Ford Mustang 3.8L
We're getting spark from the plugs but they dont smell like fuel. Thinking its a fuel pump problem. I will turn the key for a good 15 seconds but it never even gets close to starting.
Old 01-18-2011, 03:06 PM   #4
danielsatur
1) Is there any fuel at the rail?
2) Did you try some starting fluid?
If no fuel at the rail, check the fuel pump fuse, fuel pump relay, and fuel filter.
danielsatur is offline   Reply With Quote
Old 01-18-2011, 04:41 PM   #5
Andyman150
There is no fuel at the rail. I'm not getting any pressure from the fuel tank. I'm beginning to think its either the fuel pump or the FPDM module. Is there a way I can test to see if the fuel pump is getting power? If it is the fuel pump that went out, is it difficult to replace?
Old 01-18-2011, 10:29 PM   #6
Blue)(Fusion
Short out the fuel pump with 12V power. If you hear it run, it should be working and you should check into the relay or other electrical components relating to the pump. If not, you need a new fuel pump.
Old 01-19-2011, 02:06 AM   #7
Andyman150
Update. So today we replaced the fuel filter and when we took the fuel lines off we only had a few drops of gas spit out. I left the line off from the tank to the filter off and tried to turn it to see if gas would spit out. It didnt. After which we unplugged the FPDM and bridged the + and - to see if we could get the pump to work and nada. My friend who drives an '01 GT decided we should take his module, which were exactly the same, plug it into mine and see if I had a faulty FPDM. We did so and still nothing. To me this points all signs to a dead fuel pump. What do you guys think? Is there something I'm overlooking?
Old 01-19-2011, 10:52 AM   #8
Blue)(Fusion
I would still verify it's not faulty wiring harness by applying 12V directly to the fuel pump. If you have a spare car battery sitting around it shouldn't take you more than a few minutes.
Old 01-19-2011, 12:49 PM   #9
Andyman150
Yeah that sounds like a good idea. The plan is to drop the tank and remove the fuel pump and then we'll apply the power to it and see if we cant hear it try to kick on. If not then its time for a new one.
My Fiat Punto Car Wont Start Ilhanx64 Punto | Idea | Punto Grande 2 10-21-2010 07:14 AM
Car wont start ethan-erickson0015 '96-'00 Civic 3 04-24-2010 11:22 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 07:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 07:44 PM
car wont start after sitting dlistro Aurora 4 12-25-2005 01:05 PM
