transmission pan leak?
So I was looking under my car today and I notice there is quite a bit of fluid on the passenger side of the output of the transmission but not at the point where the axle connects to it. However, the edge of the trans pan is fairly wet all the way around it so I know that gasket is gone. Would that gasket be bad enough that transmission fluid could spray from under it to the output of the transmission when it's under pressure? I'm not having any shifting issues of any kind out of it. I got this car used like two months ago so I'm not sure if the fluid had been there a while or not but it's still fairly thin fluid so I'm sure it hasn't. The car is a 2001 Regal GS with 120,000 miles on it.
'01 Regal GS |
Re: transmission pan leak?
no spray just leaks, no pressure on pan gasket.
it could be wind driven as you drive at higher speeds
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
any other possible leaking points it could be coming from besides the pan?
'01 Regal GS |
120K miles, you should consider a new filter, ATF, and gasket.
I attached a picture to better explain what I was talking about. But after more inspection it looks like oil coming from above but I'm not sure. What do think?
On a side note - it doesn't leak enough to leave any spots on a driveway. I was just concerned because it looks like it is a lot of fluid. Also, the oil pan gasket is leaking but I don't think the fluid could come off it onto the trans this bad. The front valve cover was replaced I know but I'm not sure if the rear was or not. What else could be leaking on the back side of the engine? I know the valve cover and the intake manifold could but anything else?
'01 Regal GS |
sounds like you need to figure out what kind of oil your leaking.
start at the highest leak after you no what oil is leaking then clean engine/trans & keep a eye on it until you see/find the leak dont no whats common on this engine i guess its a 3.8L good luck
Reuse the original/OEM pan gasket whenever possible. It is meant to be reused and is much better than the flimsy rubber or cork ones that come with your new filter. Furthermore they don't require the use of any kind of adhesive, gasket sealant, RTV, etc....
I also agree that you still need to determine the source of the leak before doing anything.
My rides: 2007 Chevy Equinox LT FWD 2018 Chrysler Pacifica Touring L "If women don't find you handsome, they should at least find you handy!" - Steve Smith (Red) |
In any case it needs to get resolved since it will get worse.
