Old 09-12-2003, 03:37 PM
EZ_Mac EZ_Mac is offline
Send a message via AIM to EZ_Mac Send a message via Yahoo to EZ_Mac
92 Lude.....F22a....what are the engine specs...HP..SOCH DOHC,...etc.
just want to know about it....I just bought it and want to know the stock ratrings and what are the best mods for it
thanks
EZ
Old 09-20-2003, 12:16 PM
plum plum is offline
which one did you buy? well anyway i believe the prelude S (w/SOHC) is a 135 hp @ 5000 rpm, SI (DOHC) is 160 hp @5000 rpm, Vtec (vtec) is 190 hp at 6200 rpm
Old 09-21-2003, 12:31 PM
soccmid soccmid is offline
Send a message via AIM to soccmid
correction
the SI is 160 at 5800 not 5000, thats it
Old 09-21-2003, 08:07 PM
It is the "S"
S model with the f22a just want to know what i should do for performance and what everything will cost. Engine swaps $$$, turbos $$$ rebuilds $$$ etc. THANKS.
Old 09-21-2003, 08:54 PM
lucky
man i wish i ahd money, if i were u i would do an enigien swap and put in a jdm h22a or if u want the type s that will run you anywhere form 3 to 5 grand im guessin installed if u cant do it after that do watever wish i ahd money good luck man
Old 09-22-2003, 04:10 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
its pointless to do mods to that motor. You wont see any HP gains out of it. If i were you and i had the money, i would drop in a H22. Best bang for your buck and a direct swap. Good luck with whatever you decide to do.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-22-2003, 10:20 PM
yea i just got a 96 S and im gonna hold off on the real mods until i get a swap because integra is right...the base hp is real low and in the long run i feel your better of first saving up for a swap and working form there.... a swap will give you 55 more hp...which is real good considering its only 2g's forthe h22
Old 10-12-2003, 12:43 AM
Lude_03 Lude_03 is offline
Re: 92 Lude.....F22a....what are the engine specs...HP..SOCH DOHC,...etc.
My first prelude was an F22a and i had just AEM CAI, exhaust, 17's lowered, and I beat factory Si's all the time.... so actually .... i find bolt ons almost seemed to help that car more than my H22, it was prolly only like a second slower than my SRV.
Old 10-16-2003, 02:08 AM
crazieaccord crazieaccord is offline
Send a message via AIM to crazieaccord
Re: Re: 92 Lude.....F22a....what are the engine specs...HP..SOCH DOHC,...etc.
I would save for a swap, H22a. it should run you 3k or so. then do your normal bolt ons (i/h/e). If you dont have the money for a swap and you just want to blow your money away then go ahead do put i/h/e on the S motor. IMHO, its just not worth moding it. You can buy a used intake for like $50 for now if you want to make it sound mean
hummm im not believing the S w/ cai and exhaust was beating Si's maybe if you were a good driver and they had an AT or didnt know how to drive. The S' are pretty slow.
T
~*Theresa*~
1994 Prelude VTEC
1994 Accord EX 4dr AT SOLD
-->Kansas City Prelude Owners Group<--
Old 10-16-2003, 02:35 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
isnt it the f22b2, I could have sworn the accord DX/LX came with the 130 hp f22b2 and it is SOHC non vtec and the EX came with the 145 HP F22a1 that is SOHC VTEC.
and the base lude came with the base accord engine, and last time i looked under the hood of a base model it was a f22b2.
and go for the H22, its only 2200 complete swap, and wont it not even ned the axles or shift linkage, i know its already cable, but not sure of axles anyways if you domnt need that stuff its only 1950. add 300 for the LSD while your at it
http://www.hmotorsonline.com/shop/sc...age&item=30016
for about 2500 you could do the swap, or you could get I/H/E and a wet it and be able to beat SI's, but the vtec would still have you and theres not much room to go except for expensive stuff. if your tight on money, get just an intake and then a nice N20 setup and spray til you can afford the swap and then put the juice to the H22 and be extra quick.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 10-18-2010, 08:45 PM
phipps_chase phipps_chase is offline
ok i disagree with you guys talking about a swap from the f22a to the h22.. the f22 is the ideal motor for a turbo because of its low compression at 8:8:1. where the h22 is like 10:8:1.. so if i were you i would put a small turbo running 8-12 pounds of boost and that sucker will fly also the f22 has a bullet proof bottom end so you dont have to modify the engine any..
wat are the engine specs for a 2000 z24 cavalier? no_import2007 Cavalier 7 03-17-2007 02:43 AM
what are the clearance specs for porting 350 heads? clampjockey General Discussion 2 04-23-2006 09:04 PM
what are the hp/torque specs on a duster? tomahawk General Discussion 1 07-14-2005 03:16 AM
what are the stock specs for a 96 integra rs prototype80 Let's get Technical! 2 09-23-2004 06:40 PM
92 Prelude F22a what is the HP???? EZ_Mac Engineering/ Technical 11 10-01-2003 03:00 PM
