Old 11-12-2003, 01:34 PM
Bubba46 Bubba46 is offline
Send a message via Yahoo to Bubba46
Question 85 Camaro all Digital
Hi
Picked up an 85 Camaro Berlinetta for my son for transportation. Aside from numerous repairs car has 4bbl carb, set at fast idle, redid carb, now can get idle but has major flat spot in acceleration. Any hints as to problem would be appreciated. Looking for a good publication that would include vacuum diagrams etc.
Old 11-13-2003, 11:31 AM
StingRay_68 StingRay_68 is offline
It's an 85 berlinetta...it's GONNA be flat in acceleration. Check your timing and make sure the secondaries open up all the way. As long as the brake booster pump is connected to the upper vacuum and all the other vacuum nipples are either plugged or have an accessory attached then you should be fine there.
It's just an old car with an equally old engine... best bet is to completely rebuild the engine if nothing else works. Might be just worn out.
Digital Speedometer Trigger Zeifer Interior 1 05-16-2010 03:35 PM
82 Camaro won't start kelshm F-Body Problem Diagnosis 3 03-09-2009 09:22 AM
HELP!!!!! 2001 Camaro all of a sudden gas is leaking burchfield76 Camaro Discussions 4 09-10-2005 07:16 PM
Camaro on Camaro all out brawl? LSGun Camaro Discussions 24 11-13-2004 12:22 PM
