Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 05-24-2010, 09:18 PM   #1
JStin
Shuts down after a hittiing bump.
About a year ago my '98 Intrigue turned off after running over a set of RR tracks. I put it in N & it started right up. Tonight I hit a pretty small bump & it did the same thing.
I've read a few of the ignition switch threads but this doesn't seem to be related.
Do I have a bad ground? Any other ideas?
Thanks.
1998 Olds GLS Intrigue 3800 Series II - 99,000 mi.
JStin is offline   Reply With Quote
Old 05-25-2010, 10:12 AM   #2
dtownfb
Re: Shuts down after a hittiing bump.
it very well could be a bad ignition switch. the bumps can jar the switch enough that it momentarily loses connection and shuts the car off.
I would also check your battery and ground connections first (it's free) to eliminate this possibility. I would also take any unnecessary charms, trinkets, stuff off of your key chain. The added weight could be a contributing factor.
dtownfb is offline   Reply With Quote
