| Register | FAQ | Social Groups | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Rod Knock
what does this sound like cause i think i have one when my car isn't warmed up in the morning and i drive i here like this chattering noise from the engine but when the car warms up it goes away.
I don't think that is rod knock cause then you would hear it all the time.
2007 dodge ram hemi sport-the tow/dd 1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies 1989 CRX(in the works)-h2b plus maybe some spray, or some boost |
its your valve tappits from the sounds of things, you need to readjust the clearences and torque em down to spec ... had to do this on my car the other day.
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
i don't have any idea how to do that could you give me details on how to
Knock, knock, knockin on heaven's..block.
Knock, knock!
Who's there? Rod. Rod who? Rod bearing! Ha ha ha haaa! I have too much free time at work. Flunky |
haha .... what do you do for a living?
This is an idea on how to do it, go get a service manual for the complete way. Jack the front of the car of the ground and put a breaker bar on the crank pulley bolt. Rotate the engine to top dead center by turning counterclockwise. Use a feeler gauge and a valve tool, looks like a combo screwdriver and wrench. Adujt so that you restiance on on the guage. Go to next cylinder 90 degrees off and do over again.
isnt there some way you can like put your thumb in a plug wire hole and turn the crank and when it makes a psssst noise that means its TDC? i dunno i think i recall seing this done on a tv show
2002 Acura TL Type S 1991 Honda Crx Si |
This noise can also be cause not by the valves but by the oil being to high viscosity like 20-50 and its really cold out. It is dry running if the oil is the problem, also low oil not a little but alot like 1-2 quarts low will cause this sound also. Just some input...
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. My first Civic love Died from 92 year old Fart not watchin out.
The first thing I'd do is change the oil....Fresh oil does wonders.
Sometimes when it is really cold out, my valves ping for 10-15 seconds while the cold/thick oil works its way up. Also, my car has 210,000 miles on it, so it burns a little bit too. I know it is time to add a quart when I hear the valves tinging
-Shawn '91 Civic DX sedan DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
a how to on the adjusting the valve tappets would be nice!
