V-8 Power?
Anybody ever seen an MGB with a V8? I've seen pictures of them, but am curious as to how they actually perform on the street and on the track. Apparently the Buick Olds 213 V8 or Rover will fit in an MGB with minor modifications?
Dog
Ed Britt |
Old Mod
![]() Join Date: Aug 2001
British Leyland actually produced the MGB GT V8 for a few years. Not many were built (around 2500) and none were officially import to the US (odd, since the US was the largest export market for MG).
Later, the Rover Group relaunched the MGB body with the MG RV8, a V8-powered roadster, in the early 1990s. Only a handful (not sure of the number) were produced as Rover readied the market to accept the MGF. All of the V8s used in production in MGs were Buick/Rover-based units. The early MGB GT V8s used the 215cid engine while the RV8 used the 3.9L version found in Land Rovers. From what I've been told, modifications are minimal to add the V8 engine to the B chassis. I have not driven any, so I can't tell you how the perform or handle. I do know of a few places that specialize in MGs, some even specialize in V8-powered MGs. |
Thanks for the information. I own a '80 MGB and am contemplating moving to a V-8 at some point. Not a high priortiy right now though.
Dog
Ed Britt |
My dad used to own a factory MGBGT V8. At that stage I was still too young to drive so I cant give any impressions on that.
I remember it though, the Hp figure is dismal but ignore that its the torque thats important. The only problem with the factory car is its gearbox, you cant thrash it at low speeds or youll lose 1st gear. The only successful way to change this is to put a different gearbox in it, a popular conversion is the 5sp unit from the Rover SD1. It does not bolt straight in however and requires transmission tunnel modifications. In 1973 the engine bay was modified to fit the V8 motor in, this change was carried through into the 4cyl shell as well so any shell after that date will fit the motor quite easily. We have alot of literature on this conversion here so if you have any specific questions just post them here.
AF's resident BMC expert One by one the penguins steal my sanity |
Oldie
I have heard the V8 spoils the handling somewhat. I dont really know, though. It would understeer alot more, because of the extra weight. Weight is the enemy
#6 | ||
The reason is its an alloy block as apposed to the steel B-Series block
#7 | |
Oldie
I'm sure there was an MG that had a handling-ruining V8, but if this unit is lighter, then by all means, GET IT!!!!
#8 | ||
Ive been in one (MGC) and was most impressed with the handling, think it must have just been the road testers were taking corners faster than in the MGB Id rather have an MGC Roadster than an MGBGTV8 anyday
#9 | |
Oldie
So the MGBGTV8 was crappy?? I'm afraid my MG knowledge is sadly lacking
. But with extra weight over the front, its gonna make the car handle worse. SO just imagine how good it would have been with a lighter engine |
#10 | |
OK Chris since you seemed to be ignoring me I looked it up a V8 engine is only 40lbs heavier than a B Series
#11 | |
Oldie
I was just getting confused. So:
They had 4, 6 and 8 cylinder models. The 4 was lightest The 6 was heavier The 8 was not much heavier than the 4 (Is it related to the current Rover V8?) Do I have it now?? |
#12 | ||
Yes its the same rover V8 that has been used since about 1970 in many cars including the Range and Land Rover, the Rover SD1 the MGBGTV8 and the RV8. Its now got alot more displacement than its original 3.5 litres so perhaps the block has been modified but its still essentially the same engine. BTW the Rover V8 origiannly came from Buick if anyone didnt know
#13 | |
Oldie
I knew!! I knew!!!
Thanks. Just one more thing: Was teh 6 heavier than the V8? |
#14 | ||
Its a 3 Litre C series Austin Motor, and in stock form it put out slightly more Hp than the stock V8 in its detuned MGB Form, however the was the V8 was detuned was easily changed back so I doubt theres a stock detuned MGBV8 left in the world
#15 | ||
Banned
Re: V-8 Power?
