Go Back   Automotive Forums .com Car Chat > Buick > Roadmaster
Old 08-28-2011, 08:40 AM   #1
ASJT3
Send a message via AIM to ASJT3
Water pump going bad replace Optispark?
Hey guys,
The water pump on my '96 Roadmaster is going bad, and sometimes sprays coolant all over the ground on startup. The engine also reports a code P0300, Multiple cylinder misfire, which I'm convinced is due to the fact that the pump sprays over the optispark as well. My question is, after replacing the water pump, do I need to replace the optispark as well?
Thanks,
Alex
ASJT3 is offline   Reply With Quote
Old 08-28-2011, 09:02 AM   #2
Tech II
Re: Water pump going bad replace Optispark?
Well, this is a kind of damn if you do, damn if you don't issue.....
Why is the car misfiring? Plugs? Wires? Coil? Coil wire? Or is it the distributor cover/rotor? Has the vehicle ever been tuned up? If so, when was the last one? Are the wires original(have cylinder numbers on them,)?
If it is the distibutor cover, you have to remove the w/p and the harmonic balancer......
If you just replace the w/p, and still have the misfire, and it turns out to be the cap, you end up doing it all over again(w/p).....
this is just like when Firebirds needed complete turneups, and you gave the customer the estimate, and they almost passed out......I would always recommend a new w/p(I just want a tuneup, why are you replacing my w/p?), if it had never been replaced, because you don't want that old one put back in and then leak on that new cap....
Just like the Roadmaster, the plugs and wires are a nightmare....
So since you have a misfire, you have to ask yourself one question:"Do you feel lucky, punk?"
Old 08-28-2011, 11:21 AM   #3
ASJT3
Always great to get help and a good laugh at the same time.
I'm guessing its the distributor cover, exacerbated by the fact that the w/p is leaking. My guess is based on an incident where the car was driven through a puddle of water and started misfiring. I suspected arching and tried spraying down the engine at night but didn't see anything.
-Alex
Old 09-05-2011, 08:16 AM   #4
ASJT3
Well I guess I get lucky sometimes. Replaced the w/p and car is running great, no problems for last 100 miles. Hopefully it stays that way
Video: Replacing water pump, belts and shaft seals on a 944 S2 Dr944S2 924/944/968 0 05-30-2011 04:05 AM
Replacing the Water Pump - 400e schri00 E-Class 0 05-23-2011 05:52 PM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
Water Pump Going Bad??? citydragon Metro 2 10-16-2007 06:17 PM
How to tell if water pump is bad (Merlin?) cfairhall Jimmy 3 01-26-2004 07:21 AM
