Go Back   Automotive Forums .com Car Chat > Kia > Sedona | Carnival II
Old 11-15-2008, 01:36 PM   #1
0falcon8
no heat in front of 03 sedona
i have an 03 sedona and the heat does not work in the front of the cabin only. the heater in the rear works fine. is there a fuse or relay that controls the damper for temperature? ("heater" fuse is fine) or a wiring harness i should check? any help is greatly appreciated! please help me solve this problem before it gets any colder!
0falcon8 is offline   Reply With Quote
Old 01-17-2009, 10:17 AM   #2
parmotinc
Re: no heat in front of 03 sedona
If this is the same problem that I had, simply open up the glove box or remove the heat and a/c panel until you have access to the sliding lever that is suppose to control hot or cold. Mine was stuck, I simply moved it down into the hot position, heat worked fine afterwards.
parmotinc is offline   Reply With Quote
