Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon
Old 07-05-2003, 02:18 PM   #1
trauma
Dinged my neon (BAD)...........Help?? Replacing front Radiator support?
The front Rad. support is f-up. Needs repaced, Found the support for $64.00 online. The org. is welded on, is there a easy whay to get them off. Besides trying to drill ALL of the welds out? And does the repacement bolt on, or does need to be welded on? The lower support looks OK, just might have to tweak it a little. If no ones able to help me here, Can you direct me to were, I might find this kind of info.
Thanks............. Trauma Joe
trauma is offline   Reply With Quote
Old 04-26-2007, 12:06 AM   #2
bully23
Re: Dinged my neon (BAD)...........Help?? Replacing front Radiator support?
you have to drill those factory welds, then weld the new one in place, just make sure youre measurements are correct when putting the new one on or youre lights will not line up nor will youre hood latch
bully23 is offline   Reply With Quote
Old 05-15-2007, 11:52 PM   #3
libby6485
you can cut it off with a sawzall but the easier way to put it back together is to drill out some spots and but a good size nut and bolt combo make sure that you do it in strong areas or you can simply weld it on if you know how just make sure everything is lined up and measurements are all on to the best you can always adjust the lights on those
libby6485 is offline   Reply With Quote
Old 05-16-2007, 11:46 AM   #4
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
^^^Did you not notice the original post is 4 YEARS OLD?
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Front Radiator Support david-b Exterior and Wheels 11 09-05-2007 10:19 AM
Help replace front & rear differential fluid 4X4 Kia 2003 Sorento 2 10-13-2006 06:22 PM
Need help replacing front struts on 01 sunfire Lances133 General Discussions 3 03-26-2006 08:28 AM
Help! replacing front passanger door smallbus Caravan | Voyager 0 12-09-2005 03:53 PM
Help!!!!!!! 89-94 Radiator Support jorgeaguilar 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 07-08-2005 02:03 PM
