Register FAQ Social Groups
Old 04-18-2007, 04:04 PM
alkemist's Avatar
alkemist alkemist is offline
Straight pipe instead of new CAT
Hey,
My 96 Buick Rivieras CAT began to rattle recently. It sounds terrible when I give the car some gas.
Considering I will not have a problem obtaining inspection in the future... and to same some dough, should I replace nthe old CAT with a straight pipe?
Old 04-18-2007, 04:28 PM
GreyGoose006 GreyGoose006 is offline
Re: Straight pipe instead of new CAT
you could, but it would probably be illegal, and cause you to fail emissions
Old 04-18-2007, 04:30 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
It will most likely be louder with just a straight pipe.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-18-2007, 11:04 PM
UncleBob UncleBob is offline
AF -Advisor
aftermarket high flow cats start around $50. Assuming its a replaceable type cat, I can't say there's a good reason not to just replace it.
btw, if you do gut the cat (or replace it with a straight pipe) the check engine light will come on and stay on.
And also: badly burned out cat like you discribe, usually points towards a long term runability issue, such as misfires
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 04-19-2007, 12:17 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
I agree with UncleBob. Buying a new cat is often the same as having an "export" pipe fabricated to fit in its place. On almost all cars after about 1989 have honeycomb style cats that usually don't cost a single HP, but they do incredible things for the atmosphere. I'm not one of those super-conspiracy pollution freaks, but I'd rather do the "right" thing instead of finding out later that car emissions really were a big deal and I should have left it on.
Can't hurt, not much money, legal, I suggest you do the cat.
Dragging people kicking and screaming into the enlightenment.
Old 04-19-2007, 03:40 AM
AF -Advisor
hehe, I won't bother preaching about emissions. Really, I think its a question of price. There are some cars/trucks that its $1500+ to replace a cat, and if your state/county has no emission testing, heaven knows *I* wouldn't replace it if it was my vehicle.
We all have our breaking point.....
But if its cheap, easy, and the same amount of work either way, then its simply the right thing to do. Cats DO clean up the emissions significantly. They don't have much effect on performance (although many believe otherwise) there's just no good reason not to replace them....when its reasonable.
This state/county though, you wouldn't be able to get your tabs like that, so you wouldn't have any choice here, even if the cat cost $1500+ to fix.
Old 04-19-2007, 04:00 AM
curtis73's Avatar
I have to laugh also at OBD2. I have a 96 Impala SS which shares the same exact cat as the 94-95 OBD1 SS's. I can buy a 94-95 cat for $125, but to get the part number that carries an OE exemption number is $649... And in CA, I'm not technically allowed to swap them until they've made me fail emissions, and THEN I have to to to a test/repair station and have THEM do the work.
I don't know which side of the fence to be on right now, either. I do believe firmly that fossil fuel emissions are a problem, but evidence suggests that vehicles aren't the main issue. I do have a problem with dragging HC from under the surface and vaporizing it into the atmosphere, but its actual effect is vastly different depending on who you talk to.
But I ramble
Old 04-19-2007, 01:38 PM
alkemist's Avatar
Guys I really appreciate this in-detail info.
If theres not much price difference, Ill do the right thing... I plan to sell the car in the future anyways.
