after t-bat crank
Well finally got around to cranking the t-bars this weekend. It was quite easy once everything was lubed. Since I wasn't ready to add leafs or shackles, I just moved it even with the rear. This only resulted in about 1/2". At first, cranked them up too far, then had to lower them. One thing that caught my attention is that the initial measurements from the ground to the frame (at a-arm bolt) was 1/4" difference from the drivers side to the passenger side. This was from stock. Is this common???? Also, the height of the wheel wells were off by more than that. After cranking the t-bars, I couldn't get both sides the same height. Adjust one to the right height, the other would be out. Finally settled out at about(+/- 1/8") 33 1/2" from the ground to the wheel wells (top). This results in 10 1/4" from the ground to the frame. Again, these measurements are different for each side (+/- 1/8"). My rear wells are about 33 1/2" from the ground. Can anyone confirm this??? Also, will adding leafs or shackles void the warranty?? I think any after-market part will be want to be sure, if not consider them purchased.
XTerra Guy
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
Yes, it's possible your frame height could be off left to right from the factory.
Using your fenders as a gauge isn't very accurate however because you could have one shock going out, or if you even turn a bit before parking the front can be uneven. Then there are always Nissan tolerances that we know aren't the most accurate. Nothing voids your warranty unless Nissan can prove that the modification did the damage. |
My X had the same problem from the factory. I don't remember the exact measurements (they're posted around here somewhere) but I think my right side was just over 1/2 lower than the left. I'm +/- 1/8" now, which is close enough for me.
or you can have problems like what I had and my driveway is slightly slopped for rain run off. but it is sloped in a funny way. Anyhow it threw off my measurement. so you need to make sure you are on a definite level surface.
Schludwiller, where is that stated about the warranty? And also, do you know if that applies to after-market warranties? I have a 100,000 mile warranty with Warranty Gold. I have been hesitant to do any mods to my X because of the warranty factor.
Thanks, MooT |
XTerra Guy
I believe it's part of the Lemon Law, and no it won't be in your owners manual. Just remember that modifcations to your truck will put you under increased scrutiny by your dealer when you go in for warranty repairs. Although if you drive in the dirt, this seems to happen as well, so I just stopped worrying and did what I wanted to my truck.
