Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-13-2003, 01:06 PM
banjorules banjorules is offline
Spark Plug Failures?
I own a '00 Dodge Dakota Quad Cab. It has the 3.9L V6 with the 4 speed auto.
Dec 2002, at 64k miles I had the engine tuned up. Within 4K miles, the engine ran rough at cold startup and developed a severe miss and the Engine Failure light lit off. I took it back and the trouble code was a "Misfire detected in cylinder #2". The mechanic determined it to be a cracked insulator on cylinder #2 spark plug and replaced the spark plug under warranty. 4K miles later, the engine started running rough at cold startup, had the same miss and the engine light lit off again. The trouble code was again "misfire in cylinder #2". Pulling the spark plug, it was found to be a cracked insulator once again. It was replaced once again under warranty. The mechanic could offer no explanation for a double failure of this type.
I have to believe the odds against 2 defective spark plugs winding up in the same cylinder on the same engine failing in the same mileage are astronomical.
All routine scheduled maintenance has been performed on this truck.
Has anyone else run into circumstances as I've described or have any ideas what could be causing a failure of this type?
Old 06-11-2005, 05:14 PM
BadAss318Dakota's Avatar
BadAss318Dakota BadAss318Dakota is offline
Send a message via AIM to BadAss318Dakota Send a message via Yahoo to BadAss318Dakota
Lightbulb
(if they were broken on the outside) Your mechanic didnt use the rubber insulated spark plug socket, is my guess that the insulators wre minorly cracked on installation and the heating and cooling of the motor finished the crack the rest of the way though.
Old 01-05-2008, 10:13 PM
w9awx w9awx is offline
Re: Spark Plug Failures?
Sounds like a incorrectly installed spark plug. Was it the same mechanic who installed both spark plugs?
2009 KIA Rio SX AT
1995 Eagle Summit DL Coupe
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 06:19 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 09:19 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 09:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 12:03 PM
Spark Plugs + Spark Plug wires ricodemus Engineering/ Technical 4 02-27-2002 01:23 PM
