Register FAQ Social Groups
Old 01-25-2006, 02:05 PM
blueboost's Avatar
blueboost blueboost is offline
Scale Modeling Glossary of Terms
I was having a laugh after reading something similar for "mechanics tools". so I came up with a few for modelers. Add some that you come up with!
model glue- used to create a white haze on clear parts. Also used to bind wheels and other movable parts together, as well as permanently staining fabric.
airbrush- used to overspray paint onto various items in your workspace. Atomizes paint so that the mist can settle on random objects of value.
air compressor- used to exercise eardrums. Perfect for getting rapid police assistance in apartment homes.
paint brush- used to give the appearance of hair or even fur on your models. Detail brushes can also be used to get tiny dots of paint on small parts that surround the piece you are currently trying to paint.
enamel paint- in bottle form this is used to paint your hands, clothes, and spill onto modeling directions and other supplies. In rattle can form they are used to create orange peel and shoot paint sideways.
primer- used to melt models, also to react and bubble up future layers of paint.
X-acto- used to cut deep crooked lines around areas you are currently trying to score. Used to create tendon viewing areas on your finger tips.
sand paper- used to create fine styrene dust, also known as vitamins for your lungs. Can also be used to remove small details around areas currently being sanded.
thinner- used to end up on finished surfaces and pieces that were painted and put to the side to dry.
toothpick- used to play "hide and go stab yourself in the foot"
Old 01-25-2006, 02:52 PM
quadzero's Avatar
quadzero quadzero is offline
Re: Scale Modeling Glossary of Terms
tweezers-small instrument used for studying the ballistic properties of tiny plastic parts as they are launched into oblivion.
Old 01-25-2006, 03:53 PM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Perfect definition. I love it.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 01-25-2006, 08:35 PM
quadzero's Avatar
ca glue- A magical substance for introducing others to the hobby by getting your spouse to carefully cut your fingers free from the desk after you have been shouting for help for 40 minutes.
pin vise-A surgical instrument for drawing blood samples from your fingertips. Helpful for determining coffee, midnite oil, sugar, model glue, and paint content in your system.
sorry, couldnt resist that one.
Old 01-25-2006, 09:23 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Cutters: Used for cuttin parts off of sprues, and sending them flying behind the work bench, or into the rug.
The Carpet: Works great for soaking up spilled, wet paint. Also works good as a parts magnet... although the pieces may never be found again.
Dremel: Used for cutting, or sanding parts. Normally sending them into oblivion, and grinding off the hard earned calis's on your fingers.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 01-25-2006, 10:45 PM
hyobum hyobum is offline
Microsol - Vineger
Old 01-26-2006, 12:16 AM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
Webcam/ Phonecam - used to show everyone great pics of your car.
Old 01-26-2006, 07:43 AM
klutz_100's Avatar
Very creative and funny - thanks for the entertainment
"Tweezers" and "Sandpaper" are my favourites - they are just soooooo true!! (maybe they should be added to the FAQs?
It's good to be able to laugh at your own mishaps!
Lets have some more blueboost and quadzero!!
Old 01-26-2006, 06:05 PM
quadzero's Avatar
BMF-this super thin adhesive backed material is used for creating realistic chrome balls any cat would be proud to play with.
PE parts- delicate intricate aftermarket parts used for holding huge globs of ca glue in place while it cures.
rubbing compound- a paste that is used for removing blemishes in the paint such as orange peel, dust, fingerprints, ca glue, and/or cat hair and exposes the bare plastic in preparation for a soaking in brake fluid or oven cleaner so the part can be repainted all over.
(ok, i have no life, rats)
Old 01-26-2006, 06:07 PM
quadzero's Avatar
Old 01-26-2006, 06:32 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Originally Posted by hyobum
Microsol - Vineger
Tamiya Acrylic Thinner-Overpriced Rubbing Alcohol
-Mike
Old 01-26-2006, 07:05 PM
klutz_100's Avatar
TS-13 - Handy sized aerosol alternative to CSC. Can also be used to effectively remove paint from panel lines.
weredafukitgo! - Modeler's chant used to celebrate the ritualistic phenomeon of transplacement of the smallest parts detached from the sprue from the here and now into the never never land. (e.g my Dino 246GT gear lever)
Stash - 1. archaic banking term. More commonly known as overdraft; 2. The name for an assortment of boxes containing cheap pieces of plastic which have been purchased for exorbitant prices at web based auction houses for their rarity value as collectors items. It is a well known fact that at least 50% of these stashisms will be re-released by the manufacturer within 6 months of purchase.
Old 01-27-2006, 12:47 AM
Bottled paint - Comes in various volumes from 10ml to 30ml, usually used to hold paint. Mostly used to frustrate user by leaving paint in the threads of the cap therefore drying and sealing the bottle. Blisters on hands may be induced.
Airbrush propellant cans - Often mistaken as airbrush propellant, but if used correctly, by holding the can upside down, will freeze many small objects with ease.
Foot - The ultimate tool used for obliterating plastic parts that have found it's way to the floor.
Old 01-27-2006, 01:21 AM
bigfrit's Avatar
bigfrit bigfrit is offline
Pet often referred to when looking for lost parts, these animals (often mammals) have a natural urge to find and ingurgitate them. Pet's are a modeler's best friend.
Fumes Modeler's real reason to be painting. Fumes give modeler's what they call "a buzz". May cause heavy dependency.
Hands Often mistaken for cutting mats. A modeler can be recognised by so called "modeler's hands"
Modeler's hands Beginning modeler's hands have most of their digits still hanging. Average modelers suffer from permanent marks of irreversable paint incidents. The solution is using a metal brush on these to get rid of any unwanted pigmentation. Also, modeler's hands can be diagnosed by deep cuts in the thumb-area, causing spontaneous bleeds.
Box Hogging Term originated from psychology. Can be mistaken for obsessive compulsive purchasing. Is in fact obsessive compulsive purchasing. Modelers from all grades tend to buy more then they can consume. Close related to Binge shopping.
Local Hobby Shop, or LHS Providers, dealers of the modeler. These dealers are often consulted to get rid of Obsessive compulsive purchasing (see box hogging), with the opposite result.
Panel lines recurring problems with molding process. Average builders get around those by spraying an amount of paint over these, thus covering these mistakes in the original kit.
Weathering Technique used to cover up flaws in past modeling steps.
Build plan or instructions Inside joke that keeps coming back in every manufacturer's boxes. These are used to mislead builders. Often neglected by above-average users and used as cutting mat or paint-mixing apparel.
Life (As in; get a life) = modeling
Modeling see: life, addiction
Awesome random comment, see "great"
super thread guys!
hehe, we should make a sticky grouping all stuffs!
Oli
Old 01-27-2006, 01:41 AM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
Online Forums: Used to procrastinate builds or develope delusions of grandeur, often developing into n00b bashing syndrome. Also useful for finding OOP kits you cant locate but will pay high dollar for. see E-bay
Tamiya Warfare: Tactic used by top model manufactures to force consumers to buy "detail sets" to achieve same quality they did from kits two years ago, only to turn more profit then before and spend less on tooling.
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
