Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Register FAQ Social Groups
Engine intakes, exhaust, turbos, nitrous.
Old 01-12-2002, 08:04 PM
P10Skin P10Skin is offline
How much NOS?
Hi Guys
I am seriously looking at getting a NOS set up what is my best option? (frogger, wet, dry etc)????? and How many HP could the engine run with out me having to install new pistons and rods?
Cheers
John
http://www.nzprimeracarclub.cjb.net
Old 01-12-2002, 09:00 PM
kenchan's Avatar
kenchan kenchan is offline
as soon as the weather gets warmer here, I plan to do a zex 50shot (dry kit). guessing that I can put down about 150hp at the wheels...so about 0-60mph 7.5sec, 1/4mile 15.0sec
good enough for my commuter sedan.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 01-12-2002, 10:31 PM
I was thinking sumthing along the lines of a power shot 50-100 HP would this work? or am I better witha frogger system of the same HP?
Old 01-13-2002, 01:35 AM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
NOS good enough for your commuter? it doesn't do anything unless the button is pressed so the car is still slow as before...even when NOS kicks in, only faster for a little while.
P10Skin, there are a lot of other options than NOS that can make your car faster. If you are building a drag car, go for NOS because that's its ONLY purpose. For a street commuter, you want power and torque ALL the time.
Luke C.
GDA Power!
Old 01-13-2002, 01:37 AM
Nah the main purpose for NOS in my car would be power on tap for the odd drag run I do, Burnout comps and beating hondas at lighs
Old 01-13-2002, 02:35 AM
p_r_i_m_e_r_a's Avatar
p_r_i_m_e_r_a p_r_i_m_e_r_a is offline
Send a message via AIM to p_r_i_m_e_r_a
I do have to agree with G22DET,
IMO once you get those x-tra HP's you will regret not "always" having them on tap.
But I'm also positive that a local shop can provide you with a
100shot NOS in about 4-hours.
Hey either way it's still a big step in making you ride faster
Thats all that counts.
________D________
  • 94 P10 w/mods
  • 92 P10 stock
Old 01-13-2002, 02:59 AM
But is the engine capable of runnign 100 HP NOS with out taking damage? and what is my best choice as far as injection goes? wet, dry, frogger? etc
Thanks
John
Old 01-13-2002, 09:57 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Thanks
John
Without getting some sort of GOOD ecu tuning that would be very pushing it. You could probably get a 50shot with some sort of piggy back fuel richener and be OK. But for a 100shot you should probably look into getting a JWT NOS ECU upgrade. I've heard really good things about this upgrade from NOS people.
Old 01-13-2002, 06:10 PM
I've seen multiple Sr20's running 150-shot NOS with precise engine management, so yes a 100-shot is possible.
For starters, and to play it safe a 50-70 shot is the way to go.
I'd recommend buying a MSD ignition system no matter what you decide.
A direct port setup will help each cylinder gets its fair share of NOS.
Does anyone know the current price of a JWT NOS system?
________D________
  • 94 P10 w/mods
  • 92 P10 stock
Old 01-13-2002, 07:48 PM
What about timing???
as far as I understand when Nitros is compressed it brakes into oxygen and nitrogen so u have to add more fuel to the mix to keep the mix correct but wouldnt you also need to advance or retard the spark to give it the proper amount of time to burn????
Old 01-14-2002, 08:19 AM
G-Forces's Avatar
Banned
I'm not exactly sure but I think it's and extra $400 over the price of the ECU upgrade. Expensive but it's about as good as you're going to get. NOS support right in your ECU, sweet stuff.
Old 01-14-2002, 02:45 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
id go with a dry nos setup. ive heard that wet can really hurt your engine why not get a turbo and prolong the life of your engine? or get a DET at that?
1.6 - The Underdog
GA16DE-T Club!
Old 01-14-2002, 06:40 PM
This is interesting............
Nitrous Oxide Systems, the leader in nitrous technology, is announcing the availability of the worlds most sophisticated nitrous delivery system ever…. The NOSzle™. This patented new nitrous delivery system is so revolutionary that that it makes all other direct port wet nitrous systems obsolete.The NOSzle system is available for 8 Cyl. P/N 08008NOS, 6 Cyl. P/N 08006NOS, and 4 Cyl. P/N 08004NOS, EFI engines. The NOSzle system is capable of producing 75 to 600 bolt on horsepower.
The NOSzle system allows for direct port nitrous delivery on any MPI style manifold with no drilling or modifications to the manifold itself. The NOSzle simply fits under the existing fuel injector delivering nitrous and added fuel at the injector for optimum nitrous distribution.............
http://speedoptions.com/news_curren...search&v=1&pg=0
________D________
  • 94 P10 w/mods
  • 92 P10 stock
Old 01-15-2002, 05:47 PM
ericdd's Avatar
ericdd ericdd is offline
Send a message via AIM to ericdd
Cheater system
I was wondering if with the sneeky pete cheater system ( small 10"x2" bottle) if you need to increase your fuel with the shot. I want an extra kick but don't want a huge kit that will ruin my motor.
99 infiniti G20t
Stillen cold air intake
91' intake cam
jdm DET valve cover
Ractive muffler
advanced timing
wings west lip
eyelids clears all around
To many other mods to list
Check out my site
www.g20style.com
Old 01-16-2002, 03:36 AM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
I think the JWT ECU and NOS module run in the neighborhood of $1200, don't forget for anything over an 80 shot of nitrous your injectors (and possibly the fuel pump, i'm not sure) will be very close, if not maxed out, so you'll have to upgrade those as well. That's not including all of the nitrous equipment as well. It adds up quickly. A friend of mine is running all this on his Sentra SE-R, and to do it properly (aka.. still have the motor running after you squeeze) it does cost money, he's going to run the 100shot and he upgraded the injectors (i think he went 50lb (or 550s?) cause he's eventually going turbo and got a nice walbro fuel pump (i think, it might be a TTZ pump, but i'm pretty sure it's a walbro). Hope this helps
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
How Much Nos ??? BrazilianVTEC N2O | Turbo | Superchargers 11 11-12-2004 01:26 AM
how much nos can safely be used on my civic? Lxcivic4u '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 25 04-08-2003 09:10 PM
How much NOS on a stock Civic Engine? WesleyB1211 Forced Induction 39 12-28-2002 06:38 PM
how much money will this take from me and how much power will i get from it? kyle95g20 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 12-07-2001 12:49 AM
