Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Register FAQ Social Groups
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 04-13-2004, 10:43 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
fiberglassing a subwoofer, keeping it airtight?!?!
first off, why do i need to keep it airtight
and finally, in my custom box, how would i install a terminal and still keep it airtight? some sort of sealant or what?
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 04-13-2004, 11:16 PM
mjshort18 mjshort18 is offline
Re: fiberglassing a subwoofer, keeping it airtight?!?!
you need to keep it air tight, i'm not sure of the exact reason but i know you need to keep it air tight unless you are building a ported box. when you put a terminal cup on it you just need to seal it with silicone or something to that effect. you could also just drill a hole the size of the wire in the box and then seal it up with the silicone.
Old 04-14-2004, 03:22 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
For the terminals, just use a hole saw, and either caulk, or silicone sealant, you get the idea. You have to keep it airtight because the air will change the way the speaker performs, just like ports change the way it performs. If you feel the need to, run some sort of sealant around the corners on the inside (if you can).
Old 04-16-2004, 09:38 PM
BOOTY023 BOOTY023 is offline
Banned
subwoofers are built (the cone) to produce bass. ok that was obvious but more technicaly it is litterally thrown up and down violently enough that if run w/ to much restriction or, on the other end of the spectrum, in an ambient pressure, it will not last you as long as you would hope! even a ported box provides restriction but obviously less than that of a sealed enclosure.
check the factory recommendations
Fiberglass Kit for 1997 Aerostar teakstone Aerostar 1 09-25-2009 08:10 PM
Why do my subwoofers keep shutting off? metallica_pyro Car Audio 1 03-30-2009 07:34 PM
Fiberglass subwoofer enclosure? whosandy Car Audio 6 01-26-2006 05:30 PM
Custom Fiberglass subwoofer boxes 2000 neon tplaya07 Neon | Plymouth Neon 0 10-19-2005 11:00 PM
Custom Fiberglass Subwoofer Box for Wranlger Jared234 Wrangler 0 01-05-2005 11:49 PM
