Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 11-29-2003, 04:56 PM
uddiver_1979 uddiver_1979 is offline
Question 97 740iL engine noise
Recently bought 97 740 iL. Knew it needed valve cover gaskets and a repair of a vacuum problem. Both fixed. I'm getting a whine which seems to come from the front portion of the engine, but is difficult to pinpoint. Sound is more pronounced in D than P. Goes away in N. Also goes away when engine speed goes about 1 K RPM.
I've read a rear main oil seal failure can cause a similar sound, and I've tried opening the oil filler cap when sound is present. This did not make the sound go away.
Suspecting fan clutch, hydraulic pump or power steering pump. Any ideas would be greatly appreciated. Worst case, I'm concerned this could be a transmission problem - - the sound doesn't bother me too much unless its a sign of a significant problem.
Again, thanks in advance for any help or ideas anyone can provide.
Old 12-03-2003, 12:16 PM
jarhed jarhed is offline
Send a message via AIM to jarhed
Re: 97 740iL engine noise
Not that I know, but it appears to me that this might be a tranny issue. Have you had it checked?
Old 12-17-2003, 07:30 PM
Bigmike60 Bigmike60 is offline
engine noise
There is a filter at the firewall between the engine and transmission. It's very hard to get to. If it is clogged, it will cause your transmission to make a loise. It can get really loud. I had mine changed and was greatfull it was not the transmission.
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 10:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 07:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 10:03 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 07:25 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 07:23 PM
