Old 07-07-2003, 04:34 PM   #1
aaroncrombie
aaroncrombie's Avatar
plug wires for detail questions
Searched and saw it recommended to use 30 gauge wire from radio shack, but how to attach to distrib/engine? Any tips??
Thanks.
aaroncrombie is offline   Reply With Quote
Old 07-07-2003, 08:39 PM   #2
primera man
"P-Man"
primera man's Avatar
You will need to buy a pin-vise and small drill so you can drill holes in the heads/dist.
Or you can buy pre-wired ones already done.
View All My Models Here.
primera man is offline   Reply With Quote
Old 07-07-2003, 09:40 PM   #3
Juan Robles
Juan Robles's Avatar
Also you will need super glue to atach the cables. It is a good idea to subscribe to recieve a speed shop catalog like summit or Jegs to have reference where the cables go.
Also it make the wiring more realistic if you follow the firing order of the particular engine you are building.
Current projects: , 49 Merc (100%), 99 Celica (100%), 72 Corolla (100%), Lexus IS 300 (100%)
NEED MORE PROJECTS!
Juan Robles is offline   Reply With Quote
Old 07-07-2003, 10:39 PM   #4
935k3
935k3's Avatar
If using the Radio Shack 30ga wire use about a number 77 drill for the holes. Use a pin in the pin-vise to center mark each hole.
935k3 is offline   Reply With Quote
Old 07-08-2003, 12:43 AM   #5
IwannaDRift
IwannaDRift's Avatar
Send a message via Yahoo to IwannaDRift
I used some wiring from somekind of electrnic board
"It makes you feel gooood.."
FAQ's of life....
IwannaDRift is offline   Reply With Quote
Old 07-08-2003, 12:49 AM   #6
CamaroSSBoy346
CamaroSSBoy346's Avatar
Send a message via AIM to CamaroSSBoy346
my super ghetto way: drill 1 big hole in distributer, glue 8 wires (all 8 wires cover the hole) [i mostly wire v8's anway] and then tuck the wire behind the exhaust header
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
CamaroSSBoy346 is offline   Reply With Quote
Old 07-08-2003, 08:26 AM   #7
freakray
AF Modelrater
What about the ninth wire?
There is a wire to the coil too.....
AF User Guidelines
freakray is offline   Reply With Quote
Old 07-08-2003, 09:42 AM   #8
aaroncrombie
Thanks! I'll get a pin vise then and some bits.
Old 07-08-2003, 09:51 AM   #9
Jonno
Jonno's Avatar
Send a message via MSN to Jonno
I was about to say the same thing...
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Jonno is offline   Reply With Quote
Old 07-08-2003, 11:55 AM   #10
008
008's Avatar
The Camaro in the pic has HEI ignition and therefore only has 8 wires. So he's excused, for now. Don't show us a non-GM V8 without a coil wire.
008 is offline   Reply With Quote
Old 07-08-2003, 02:54 PM   #11
Honoturtle
I use wire that i bought at a arts/craft store made in a variety of colors. I get 40 yards for $2.00 USD.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Honoturtle is offline   Reply With Quote
Need Wiring info for E350 Cruise Module jdemaira Econoline 0 01-18-2011 03:16 PM
replaced my plugs and wires on my 2002 Gc sport 3.3 chevyn0va1 Caravan | Voyager 4 10-24-2010 07:38 PM
plug wires for 4g64? crazy_ugly_coyote Eclipse 2000+ 3 08-23-2004 07:06 PM
spark plug wires for b16a1? crxsirpr '88 - '91 Civic | CRX | Wagon | Shuttlee 4 02-22-2004 02:23 PM
What size wire for detail??? Deejay27 Car Modeling 7 06-11-2003 12:41 PM
