Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 06-07-2011, 02:45 PM   #1
northern piper
northern piper's Avatar
2000 3.8 with brake squeek
HI
Wife's kid mover, my maintenance chore. I've done the front and rear brakes a number of times on the van. Over the past 2 months the brakes squeek, kinda like the sound a transit bus makes, not a pulse or grind, squeek. It's less when you really push on the pedal but rolling to a stop it really squeeks. The pads are at 3/4 thickness, the rotors were new when the pads were installed. Haven't checked the rears but am pretty sure it's coming from the front. Last weekend I removed and lubricated the 4 sliders on the calipers. I'm kind of wondering why this sound is here now. Pitted or scored rotors? Fyi, raybestos pads..
Brake pad wear is even, calipers were new at last pad/rotor changeover.
Ideas?
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
northern piper is offline   Reply With Quote
Old 06-07-2011, 08:35 PM   #2
fy171
Re: 2000 3.8 with brake squeek
i have 2002 did new drums and rotor ,shoes and pad had the same problemb,i bought new rotors for the front same thing replace the pads and noise went away try different pads
frank
fy171 is offline   Reply With Quote
Old 06-08-2011, 12:06 AM   #3
olopezm
olopezm's Avatar
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Try lubricating the tracks at the anti rattle clips, if these are completely dry, can cause the noise you´re hearing. You can also put some high temp sealant at the brake of the pads and glue them to the caliper and piston. This will reduce the amount of vibration between the components and all noises should dissapear.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
olopezm is offline   Reply With Quote
Old 06-10-2011, 08:19 PM   #4
northern piper
so just following up here.. I pulled the calipers off last night. Everything looked fine so I scuffed the rotors up with some 120 grit emery paper, cleaned them off with brake part cleaner and reassembled. The noise is gone now. I dunno if it'll be back but that seemed to solve the problem. The surface of the rotor did seem very polished and scuffing did of course remove that shine. Hopefully the noise is gone for good!
2000 windstar 3.8
Muskoka Canada
2000 SEL 3.8 air conditioning troubleshooting a/c Nox Windstar 6 06-20-2010 09:29 PM
3.8 head changes. help? thunderbirdcoupe89 Thunderbird 2 12-10-2009 12:43 PM
Problems with 2000 3.8 LS elitemp1984 Impala | Impala SS 10 10-12-2006 06:34 PM
2000 3.8 Camaro, no acceleration with WOT jstbecauz Camaro Discussions 9 01-31-2005 11:08 AM
Best thing to start with for a 2000 3.8 Firebird Dildozer Camaro Discussions 23 01-18-2004 11:45 PM
