Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 10-18-2010, 02:03 PM   #1
rulemob
Question 91 geo metro clutch adjustment
I have a 91 geo metro that is a manual and now its getting harder to shift into second gear and almost impossible to shift into first gear when you come to a full stop. To shift into first I have to put it in reverse then into first it will go. Is there a way to adjust the clutch or should i just replace it. The person that previously owned it replaced the clutch before i bought it over 40,000 miles ago? THANKS
rulemob is offline   Reply With Quote
Old 10-19-2010, 04:08 AM   #2
Woodie83
Woodie83's Avatar
Re: 91 geo metro clutch adjustment
Could be that there is too much slack in the clutch cable. If you look under the hood, about midway between the battery and distributor, but lower down, you'll see where the clutch release arm connects to the clutch cable. The end of the cable is a big round nut that serves as the adjustment. If you can mover the lever with your hand more than a millimeter, the cable is loose. Tighten it up until the lever won't move, then back it off one turn.
That lever is known to crack on the other end where it clamps onto the clutch release shaft and slip, also the shaft bearings sometimes get dry of lube and sticky.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Woodie83 is offline   Reply With Quote
Old 10-19-2010, 11:22 AM   #3
rulemob
That worked thanks
'96 Geo Metro Clutch Slip dsmess Metro 0 04-24-2010 07:10 PM
Metro Auto Trans Mount FUBAR ManicMetro Metro 1 01-11-2010 09:15 PM
96 geo metro crankshaft pulley bolt keeps snapping krayziemike4202 Metro 5 11-16-2009 05:38 PM
1997 Geo Metro LSI 4Cly Auto shitfing Problem Zechariah Metro 2 09-28-2009 07:09 PM
96 Geo Metro Lsi with tapping rockers AsylumEscapee Metro 0 07-13-2009 03:07 PM
