Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-02-2010, 09:56 PM   #1
timnmary2000
Unhappy please help
i have a 1999 s-10 zr2. it will start and idle fine, but whenever i put the truck into gear it will stall. i have replaced the following parts: tps, map sensor, ignition control module, plugs, wires, coil, cap, distributor, battery, and fuel pump. i am running out of money to throw away, please help asap!!!
timnmary2000 is offline   Reply With Quote
Old 06-03-2010, 09:07 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: please help
What engine?
Any check engine lights?
On the stall does the idle RPM slow down making it stall or does it just quit?
Or other words is the IAC controlling good RPM to keep engine running?
What are idle RPM at idle and in gear and out of gear?
Does it run good on the road?
MT
Old 06-03-2010, 03:51 PM   #3
timnmary2000
Re: please help
it has the 4.3 vortec. it won't make it to drive it on the road. the rpms are about 6-700 at idle. when you put it in gear, or turn on the heat/air the motor will idle down untill it dies. also no check emgine lights.
Old 06-03-2010, 04:53 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Re: please help
Will it run if you push the gas down some?
Check the IAC idle air control valve for working right.
MT
Old 06-03-2010, 06:32 PM   #5
timnmary2000
Re: please help
the motor will run forever if you let it sit untouched. where is the iac valve located?
Old 06-04-2010, 08:23 AM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
Re: please help
Around the throttle body area.
Round solenoid with a few wire plugged into it.
Are you getting a check engine light or codes?
MT
