In the 200 Club
1998 Explorer 4x4 4L
The drive train freewheels when going down hill in 4x4 Low, and 1st gear. Shouldn't the engine be braking the vehicle when in 4x4 Low, and in 1st gear? It is free wheeling which is very hard on the brakes; I had to ride the brakes the whole 2 miles down (a lot 45 degree grade). ![]()
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i |
SHO No Mo
![]() Join Date: Jun 2004
Re: No Engine Braking in 4x4 Low 1998 Explorer
How fast were you going when you tried to shift to 1st gear and 4x4 low!?! That combination sounds like it would top out at like 5mph! If you leave the truck and Auto or 2WD and shift to 2nd or 1st does the engine apply some braking?
-Rod |
#3 | ||
In the 200 Club
I will try some of the other combinations that you mentioned above, to see if there is any engine braking taking place there.
SHO No Mo
You mention you started out (presumably from a stop) in 4x4 low. Here's what the service manual says for engaging 4Low:
"When shifting into or out of LOW range, the GEM requires that the vehicle speed is less than 5 km/h (3 mph), the brake is applied, and the transmission is in NEUTRAL." Are all of those conditions being met? I didn't find anything in the service manual suggesting what could cause the truck to freewheel unless the 4Low is not actually being engaged due to a transfer case selection motor or transfer case issue or issue with one of the inputs needed to engage 4Low (neutral safety switch, brake pedal position switch). Are you pretty sure that 4Low is engaging as would be confirmed by a very low gear ratio? -Rod |
The Following User Says Thank You to shorod For This Useful Post: |
tinkering (07-09-2014)
#5 | ||
In the 200 Club
I will focus as you say, on whether 4Low is actually engaging. I will post my findings.
#6 | ||
In the 200 Club
I also turned the overdrive off (just in case that was the problem) by pushing the button on the end of the gear shift lever. I selected 1st/Low gear; I can feel the engine braking going down the mountain (it just doesn't brake as much as my Chevy 3/4 Ton 4x4 when it is in bull low). We tried it in 2nd gear too while in 4x4Low and it was noticeably less engine braking. I think my problem initially was: not stopping or <3 mph, not holding the brake on while in neutral, before switching to 4x4Low So we have engine braking in 4x4 Low but not as much as our Chevy 4x4. We still have to use the brake pedal quite a bit more than with the Chevy. Does this sound normal? What should the engine idle be at? Maybe my engine idle is too high (I am currently having problems with the Idle Air Control valve)? I might start another thread about that.
#7 | |
SHO No Mo
Honestly all the Mountaineers and Aviator that I have experience with have been AWD, no option for 4 Low. It does sound suspicious that you are not getting much engine braking at all when in 2nd gear. I wouldn't expect an overspeed condition to cause the transfer case to override the 4 Low selection.
Engine idle should be somewhere between 650 and 750 rpm I would expect, but I don't have the specification in front of me. -Rod |
#8 | |
In the 200 Club
This is a late follow up but better late than never. The whole problem was attributed to the PCM and fusebox that these Expeditions etc. and F150s right up to the current years are experiencing. Water gets through the wind shield seal and into the PCM and the fusebox behind the dash. I changed them out and all of the meriad of electrical glitches were no more. I also replaced the burned out dash lights. NICE. Even the intermittent problem with the key and the security system went away.
I took it into a glass shop who knew how to seal everything up properly. VOILA! I also applied sealer to those channels that travel along the length of ths roof. The factory sealer cracks and water seeps in there too. Ford isn't all better ideas. The main thing though was the transfer case began to shift properly into and out of low, with the dash 'low' indicator light smiling back at me for the first time since owning it!
#9 | |
SHO No Mo
Thank you for following up with good details on what you found the issue to be! I'm glad to hear you got it resolved.
-Rod |
The Following 2 Users Say Thank You to shorod For This Useful Post: |
tinkering (07-04-2022)
#10 | |
In the 200 Club
Thanks shorod. I always try to follow up. It's the finishing touch to the whole forum process. I like to contribute too. Automotive forums has been a lot of help over the years. Excellent.
